Old 05-23-2016, 12:18 AM   #61
rjmorel   rjmorel is offline
rjmorel's Avatar
I understand and appreciate all of the above views and reasoning on this topic from you guys. Here's another farmer John (whoever he was) idea. Cut one of the radiator hoses in two and install a ball valve so you can close down flow till it warms up to 3 bars then open it up some to get temps you want ?????? The fan switch and fill cap are still in the picture then. I know not cell phone techy enough but satisfyingly simple like a patatoe. rj
Live Zong, and Prosper
Old 05-23-2016, 06:23 AM   #62
Ron B   Ron B is offline
Ron B's Avatar
I know Kats not in the U.S. but if you start messing with the factory cooling system has anyone checked with CSC to see if it will void the warranty? Some factories and companies are really picky about changing some things from their specs. I know Chevy was real picky about what lifts i could put on my truck.
Wingless Hawk, 2016 orange RX3, 97 wide glide,2003 KLR
Old 05-23-2016, 09:18 AM   #63
katflap   katflap is offline
katflap's Avatar
I do actually like this Idea and I like your thinking rj,
I might well use your Idea as plan "C" but for now i'm going with the by pass idea as it has a few other benefits.
Here's a pdf link to some thermobob info, explaining the whole deal.
http://www.watt-man.com/uploads/TB_Testing.pdf
Old 05-23-2016, 09:29 AM   #64
katflap's Avatar
Good point Ron
We don't have anything like CSC with their parts, support and warranties
Though my bike did come with a warranty, I think there would be a less than zero chance of getting any joy with it. That said I did kinda know this before I bought the bike.
Old 05-25-2016, 08:42 AM   #65
katflap's Avatar
Coolant temp test run.
55mins of mixed speed Limit roads (30,40 & 60 mph)
Air temperature = 16c ( 61f)
Quite quickly, the temp got to 50c ( 122f)
Took what seemed like quite along time to get to 55c (131f)
From there on the temp stayed pretty much between 55-60c (131-140f)
At one point I stopped to let the temp rise to about 75c (167f), but once riding again it soon dropped back below 60c (140f).
So in nearly an hour of riding the coolant temprature didn't get hot enough to open the thermostat (rated at 70c 158f) (apart from my stop).
I can only assume that the radiators being warm is due to the small bypass hole in the thermostat. I think I will be testing the thermostat at some point.
picture - a few mins after returning. Naturaly the temp has gone up some.
Old 05-25-2016, 12:36 PM   #66
You are a wonderful asset to these forums, Kat.
After I return home from a ride, I am going to open up my spare thermostat housing, and measure the thermostat. I will also try to post some photos.
Old 05-25-2016, 01:45 PM   #67
kohburn   kohburn is offline
kohburn's Avatar
sounds like testing the thermostat in a pot of water with a thermometer is in order.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 05-25-2016, 09:19 PM   #68
Here are photographs of my spare thermostat housing, and the thermostat itself. The thermostat is 1.25-inches in diameter, and appears to be an excellent match for the Thermo-Bob spare thermometers.
For comparison, here is a photograph of the 1.25-inch thermometer for sale at the Thermo-Bob website.
http://shop.watt-man.com/Thermo-Bob-...rmostat-S3.htm
Old 05-25-2016, 09:35 PM   #69
dpl096   dpl096 is offline
dpl096's Avatar
Great work Kat &Spud. This thread keeps getting better
― Thomas Jefferson
Old 05-25-2016, 09:58 PM   #70
Kat,
I think you could install a 90 degree Celsius thermostat from Watt-Man in the thermostat housing.
Then you could follow your plans, as stated in post #26 of this thread. You could remove the temperature probe for the digital display, and use this port for the bypass hose to the water pump inlet. Then you could install the temperature probe for the digital display in a new connector, placed just upstream of the thermostat housing.
Old 05-25-2016, 09:59 PM   #71
Well, 70C = 158F so that is one reason why the bikes do not get very hot. With two radiators the system can shed serious heat without ever getting too hot. On the other hand, that thermostat setting will tend to keep the engine at 158F just as long as possible...probably all day. I suspect a 180 or 190F thermostat would be a good idea here. A small bypass still looks like a good idea to me.
Old 05-25-2016, 10:02 PM   #72
Looks like Spud beat me to the punch and is thinking along the same lines. I like the idea of re-purposing that sensor hole for a bypass. Man, we might be onto a fantastic idea here!
Old 05-25-2016, 10:08 PM   #73
I think Katflap's plan is excellent.
Our thermostat housing will accommodate one of the spare, $19 thermostats sold by Watt-Man. Even if we bought a Thermo-Bob kit, we would still need to fabricate an appropriate bypass connector for the short hose coming from the right radiator to the water pump inlet. Therefore, rather than buy a Thermo-Bob kit, I think it would be less expensive to follow the plans of Katflap, as outlined in post #26 of this thread.
Old 05-25-2016, 10:11 PM   #74
...I like the idea of re-purposing that sensor hole for a bypass. Man, we might be onto a fantastic idea here!
I agree.
RJMorel has joined this discussion, and he is a machinist. What do you think, Rob? Can you recommend some appropriate connectors? If not, can you fabricate what we need?
Old 05-25-2016, 11:14 PM   #75
The temperature probe for the digital display has an M10 x 1.0 thread pitch. It would accommodate the following adapters.
http://www.ebay.com/itm/Black-3-8-ba...ZWxdMP&vxp=mtr
http://www.ebay.com/itm/Black-5-16-b...9WxdFg&vxp=mtr
http://www.ebay.com/itm/Fitting-M10X...dWiY1n&vxp=mtr
http://vibrantperformance.com/catalo...d349f3b2e99afd
