Old 03-06-2015, 11:21 AM   #61
Originally Posted by No1Vic View Post
Interesting thread..... I like to see what's going on with any vehicles I have so think I'll be making up a lead to see if I can connect to the OBD port, got an assortment of diagnostic software and adapters so see what I can do. If I have any luck I will share the results on this forum :-)
That would be terrific!
Honestly, the skill set of our members is amazing.
Old 03-17-2015, 08:59 AM   #62
No1Vic   No1Vic is offline
No1Vic's Avatar
Right I'm going to spend the day looking into making an OBD connector for this bike, see on the wiring diagram there is 6 wires to the diagnostics port, both K-line and canbus connections..... I will try the K-line first (easiest) and see if my diagnostic gear picks up anything then look into the canbus connection ... I see there is a note on Delphi's pinout diagram for the ECU that canbus is used for ECM development only so maybe caution needed, wouldn't want to disable my bike .....
Old 03-17-2015, 10:32 AM   #63
I'm pretty someone (Spud, perhaps?) found an OBDII adapter for the Delphi connector. Perhaps that would take some risk out.
Old 03-17-2015, 10:48 AM   #64
Post #33 of this thread should provide the information you need. The Delphi connector employs only three wires, one of which is the K line.
Old 03-17-2015, 12:11 PM   #65
No1Vic's Avatar
Diagnostics
Made up a lead, connected to the port and nothing, no data being picked up from the K Line on my bike :-( Will have to try the canbus connections next, I've included a pic of the port pinout. I'm wondering if pin 5 is equivalent to a L line connection needed to 'wake up' the K Line communications? Any thoughts? Attached pic of the OBD adapter lead I've made, probes for 12+, ground and K-Line.
Old 03-18-2015, 03:14 AM   #66
No1Vic's Avatar
Look what I've found on good old ebay,,,,I wonder if it's worth a try: http://www.ebay.co.uk/itm/KAWASAKI-6...item2594f846cf
2015 Honley RX3
2010 Suzuki 1250 Bandit
2006 Suzuki Hayabusa
Old 03-18-2015, 10:43 AM   #67
Not a bad price, if it will do what you need.
Old 03-18-2015, 03:44 PM   #68
No1Vic's Avatar
The Harley Davidsons use the Delphi MT05 ECM.........lots of tuning interfaces available to do your own fuel mapping for them,mmmmm now then it must be research time ;-)
2015 Honley RX3
Old 04-26-2015, 03:39 PM   #69
samcool   samcool is offline
Delphi flashing tool
Hi
Here is SW for flashing Delphi MT05 ECUs
http://bitbox.ru/en/catalog/1
Maybe someone needed for tuning
cheers
Old 04-26-2015, 05:49 PM   #70
Thanks for posting the link.
Old 05-01-2015, 07:37 AM   #71
btw harley MT05 differents from all chineese
Mt05 and mt05.2 using all around has K-line to communicate
Harley MT05 - using CAN
so any tools for harley will not work
Old 05-01-2015, 10:57 AM   #72
Thank you for posting that good information.
Old 05-10-2015, 03:29 PM   #73
katflap   katflap is offline
katflap's Avatar
I have found a USB connector that looks like it might connect a laptop running the PCHUD software to the Delphi Mt05 diagnosis plug.
(I haven't checked the plug but it looks about right)
http://detail.1688.com/offer/4223376...0.0.0.0.ubmz58
(reference to RX3 in description)
and here I think is the same item on Taobao
http://item.taobao.com/item.htm?spm=...ucket=2#detail
the description suggests it might come with software.
Its a long shot but you never know it might just work
Old 05-11-2015, 12:05 AM   #74
Thanks for posting the link, Kat. You are quickly becoming a Taobao Guru.
Old 05-11-2015, 12:55 AM   #75
Nice work! Are you going to buy one?
