02-03-2018, 04:56 PM | #61 | |
Any idea? |
02-05-2018, 12:58 AM | #62 |
So I went ahead and checked all the connections on the bike and made sure everything was tight and still nothing. Went ahead and ordered another spark plug, coil, and cdi to try and rule stuff out. Will give an update once I get those parts in!
02-05-2018, 02:12 PM | #63 |
What jetting is in the current carburetor?
02-05-2018, 03:09 PM | #64 |
The carb is stock. It still has the tamper resistant screws in it
02-05-2018, 06:26 PM | #65 |
The stock jetting is terribly lean. Makes for hard starts and cold idle issues like you are experiencing. Need to jet and tune that stock carb at a minimum
02-05-2018, 07:50 PM | #66 | |
Thanks! |
02-06-2018, 01:31 AM | #67 |
sounds like you have the choke on full!
02-06-2018, 01:35 AM | #68 | |
02-06-2018, 01:36 AM | #69 |
idling rather slow too
02-06-2018, 08:51 AM | #70 |
I had it on first to get it started I have tried in half and open as well
02-06-2018, 11:52 AM | #71 |
Checked the kill switch?
02-06-2018, 08:28 PM | #72 |
That's the thing tho. I get spark but the motor does even pop. So that means the kill switch should be fine right?
And its getting fuel because of that shot of starting fluid which should get it to pop. So I'm just thinking that the ignition coil could be week or the cdi or something. All the parts came in tonight. Just have to hook it all up and see. Just to confirm the CDI is DC and not AC right? |
02-08-2018, 08:17 PM | #73 |
Well I think this story is coming to an end. I went ahead and replaced the sparkplug and the ignition coil and it fired right up. Finished buttoning it up and took it for a ride! I know I have a little ways to go, like jetting and tuning the carb. Does anyone know where I can get cheap platics for the bike?
02-08-2018, 08:51 PM | #75 |
Excellent work. Sounds nice and healthy now.
As far as plastics, the tank and side panels can be used from a tt250.
