Old 03-21-2017, 11:58 PM   #61
TheGageinator   TheGageinator is offline
LED Pods
These LED light pods absolutely rock. They murder the factory housing's output capability no matter what bulbs you have installed. They only cost $25 for the pair..... I had some $80 Tusk bulbs, and the pods are 10x brighter. I got the spot beams to replace the factory lights. I routed the wiring from the original Headlights to the LED's. Just leaving the original housings in place so it doesn't looks empty.
Planoled is the place I got them from
Old 03-22-2017, 12:01 AM   #62
ben2go   ben2go is offline
I have those on my '14 Honda CB500X. I can turn night into day when I'm caught in the dark.
Old 03-23-2017, 08:34 AM   #63
DuaneEddy   DuaneEddy is offline
DuaneEddy's Avatar
That's awesome! What do you think about the air shocks
Old 03-23-2017, 09:37 AM   #64
The shocks are garbage. I have some banshee shocks to replace them with but I havnt done it yet. The reservoirs don't work like actual air shocks. Just stuff bolted on to make it look cool.
Old 09-26-2017, 08:31 PM   #65
I have had a problem with my SunL not running right. It would run great on startup, but it would totally fall on its face when warmed up. It ended up being the CDI. After i replaced the CDI, the ATV would pull great except for at 2k rpms. at Wide open throttle or partial throttle it did the same thing. Not carb related. It ended up being the ignition coil. It has been a long time since this thing ever ran this good. I cant believe how much power it has. Between the carb swap/jets, new pod filter, exhaust mod, and new ignition components, this thing rocks.
now my suspension components are slowly going out. I need to replace the swingarm bushings, and find some control arms because 2 of the ball joints are shot.
So there is an update for ya! Getting ready for hunting season!
Old 09-26-2017, 09:50 PM   #66
Had to replace my front hubs. I decided to make a video
