04-22-2017, 10:15 PM | #601 |
What model Honda ? Do you use to look up a 45 tooth sprocket to purchase?
04-24-2017, 08:05 PM | #604 | |
There's more to this than just changing sprockets. First, the engine has to be run in. Second, main jet and probably pilot jet will have to be richer than stock. And, the mixture has to be enriched to avoid scorching the piston from too much heat. So go easy here. It's a step by step process...ARH |
04-25-2017, 05:30 PM | #605 |
I remember a guy....
Who was an acquaintence of my father who bought a new 1954 Packard Carribean with the big 212 hp engine. 359 cubes, 9 main bearings, crank shaft weighed 105 pounds. With Ultramatic II trans. But he answered my fathers question of how he was going to break in the engine with "I'll just run it to Las Vegas and back at 90 mph. It'll be fine" Well, it wasn't fine. Car always was trailed by a cloud of blue smoke. We were headed out to the high Sierras on the Vegas highway, running about 75 or so, when he passed us like we were tied to a post. Trailed by a plume of blue smoke. It was the only oil burning Packard I ever saw. My mothers car, a 1949 Victoria, didn't burn oil, so it wasn't normal. He just didn't break it in right. Metals and especially lube oils are a lot better now, but you can still abuse an engine, and not get the kind of life or performance you expected. Especially these engines that come way lean and very tight valve clearances. An over lean engine runs much hotter than a correctly jetted one. An over heated engine can stick a piston more easily than you would believe. So, my advice is don't overgear it, and run hard until you pass five hundred miles, and change the jets....ARH
04-25-2017, 05:43 PM | #606 | |
04-25-2017, 07:19 PM | #608 |
I prefer loosing my brain first.
04-27-2017, 02:15 PM | #609 |
Running in
I know that when you get your new toy, it is very difficult to not run it wide open. And, even worse, change the gearing for more top end before your check even clears the bank. Please restrain yourselves. A combination of a tall top gear ratio with a new tight engine, combined with too lean a main jet, and balls-to-the-wall riding is a recipe for a fried piston. Not always, but often enough...ARH
04-29-2017, 04:06 PM | #610 |
Look before you leap.
A few guys have been playing with the ideas of converting their carbureted bikes over to electronic fuel infection. Yeah, I hear yuh - but a carburetor is so - - - yesterday! My opinion is, count your blessings. And count your bankroll. Putting a $800 fuel injection on a $1200 motorcycle just doesn't make sense to me. But playing around with a $30 to $100 carburetor, plus a few jets, sounds like affordable fun, to me. It is not rocket science to tune a carburetor to get the most out of a 229cc motorcycle engine. There is a lot of information on this forum on how to set up a carburetor for these engines. Once you've done it, you will say "What's the big deal". The truth is--it's not a big deal! ....ARH
04-29-2017, 04:42 PM | #611 |
Can't teach an old dog new tricks
04-29-2017, 04:47 PM | #612 |
I play with carbs every day. Factually, a perfectly tuned carburetor is going to be better for power than an equivalent EFI system.
So, why do I want to convert to EFI? Carbs never stay perfectly tuned. Change elevation, it's off. Colder? it's off. Hotter? it's off. While generally putting around locally, depending on where you live, it's generally not a big deal. Let a carbed bike sit, even if you do it properly and drain the bowls, they can potentially be a nightmare - especially with modern fuels. I honestly was just toying with the idea of EFI for mine, until someone pointed me in the direction of a kit that only costs 230 bucks, and is based off the same hardware as a Megasquirt, which I do have experience with. Now, it may be an eventual reality. Worth it, probably not to most people. I guess I have just become tired of constantly fiddling with carbs over the years. Especially the model specific Keihin 4 carb setup on my Goldwing, which is especially a nightmare when they have any sort of issue, but a dream once you have them setup. Besides, the way the kit is setup, you could convert back to carb in a heart beat if you decide to sell the bike, and use it on another bike, or sell it and recoup some money. |
04-29-2017, 05:05 PM | #613 |
I don't know what year you were born, Azhule, but if was 1960 or later, I was playing around with fuel injection before you were born...LOL...ARH
04-29-2017, 05:13 PM | #614 | |
04-29-2017, 06:45 PM | #615 | |
Picture of Goldwing 4cyl carbs if interested: http://4.bp.blogspot.com/-flmgcOQHIX...587-773038.jpg All of that aside, if everything is in good shape, they work brilliantly, and even handle elevation changes well. Synching them is an easy process too, and designed to be that way. Once tuned and synced - they never waiver. Their complexity is as much their saving grace as is their downfall. On a single cylinder, I would agree that it makes less sense. It's just one carb that is easy to access, and for most people it will work just fine. For me, it's just a matter of being a tinkerer. I don't believe there is any substantial power to be gained from it. Maybe better fuel economy overall, less issues with sitting, and easier starts regardless of the weather. For $800...I wouldn't bother. For $230, I might do it, but I have no concept of money... |
