Old 12-11-2008, 03:36 PM   #46
BillR   BillR is offline
Re: dead battery
Originally Posted by puush
i got new spark plug but battery is dead.
Did you slow-charge the new battery before using it?
You may have pulled it to low and fried a cell.
Been there/done that a couple of times with the 12v deep cycle batteries I use to charge my RC power packs.
Bill
Old 12-12-2008, 12:28 AM   #47
puush   puush is offline
parts
wheres the best place to buy parts for my db-27? I will check the Strator also. Thanks for the tips.
Michael, IT Dude
From the Great Land of Lake County
Old 12-12-2008, 01:04 AM   #48
parts on wenesday
i can buy some parts on wenesday
Michael, IT Dude
Old 12-12-2008, 09:20 AM   #49
Is this one similar to your bike?
http://www.chinariders.net/gallery2/...serialNumber=1
If so, it looks to be one of the "generic" China bike 200cc motors.
Lots of links to parts suppliers in the forums.
Check the Dual-Purpose pages for parts lists.
http://www.chinariders.net/modules.p...=viewforum&f=1
Personally, I've bought parts from:
Hooper Imports
http://www.hooperimports.com/
Rabbit Scooters
http://www.rabbitscooters.com/
and off Ebay.
This member has a website and has offered to find parts if he doesn't have it in stock.
http://www.chinapartscanada.com/
Good luck and keep us posted on progress.
Bill
Old 12-14-2008, 03:20 AM   #50
my bike
yes, that looks like my bike.
I will take out carb one more time and meticulously clean all jets. If it doesn't start then I'll buy cdi and regulator. I have a new coil on bike. Remember, the bike starts and runs for a minute or so then bog out and quits.
I have a new XMoto 250 cc. I have ridden it twice and it is awsome. Taller, better handling and more taller than my DB-27. I am glad I had the DB-27 first because i would have killed myself on the XMoto if I bought it first.
I am also trying to fix my 250cc Chinese Buggie that got over heated a little. Thanks for all your help dudes. i hope I dont have lots of problems with the XMoto but the way I ride???????
Michael A
Michael, IT Dude
Old 12-14-2008, 08:43 AM   #51
katoranger's Avatar
Make sure you try a new sparkplug. I would try that first.
Allen
Old 12-18-2008, 03:29 AM   #52
Some Success!
Well, finally some success you all. Determined that the fuel filter was sketchy so I removed it and shortened the fuel hose from the tank to the carb and then put in a new spark plug. Low and behold the bike started and i kept it running and blew out the carb jets some more. I took it for a test ride and it misses here and there. When I accelerate it will cut then rev back up again. But it will start right back up again.
Also, I think some of the electrical wires might have been moving the choke lever after it started which may have caused it to bog out. For now its a good mellow "flat trail" bike. The FMF muffler makes it sound loud as hell as compared to my new XMoto 250cc exhaust.
Now it just needs a Front Wheel to replace the bent one and the large nut that goes on top of the tri clap that holds handle bars. Its difficult to find a 20mm nut in a regular hard wear store and Honda shops dont want to sell any parts for China bikes where I live. i will check out the parts websites from the previous links.
I'm not sure what to do about the slight hesitation when accelerating but I am just glad I got the bike running again like it is. Thanks for all your help dudes! you"ll go to heaven for this.
Michael A :oops:
Michael, IT Dude
Old 12-18-2008, 04:12 AM   #53
DB-27 Front Wheel
Its impossible to find a front wheel for DB-27. nationalonlinescooters.com is selling one for like $282!!! NOT!
Do you all know where i might find a db-27 front wheel???
Thanks.
Michael, IT Dude
Old 12-18-2008, 07:51 AM   #54
katoranger's Avatar
I may be able to help with that nut. I have some hondas here.
The cutting out may be electrical related. Possible a loose wire at the CDI or Coil connection. Check those first.
Allen
Old 12-18-2008, 09:02 AM   #55
Cal25   Cal25 is offline
Glad that you finally had some luck. Try to get another fuel filter installed though. The same junk that clogged the filter will clog a jet or other passage in the carb. You know which is more difficult, taking out the carb and cleaning it or replacing a filter.
Maybe this wheel would fit:
http://www.motosportsparts.com/s.nl/...&category=5708
