06-11-2019, 03:12 PM | #46 |
Yes sir! Thanks for your help. Glad you have these parts available. I have a few other things from you on my watch list to buy soon.
06-11-2019, 07:20 PM | #47 | |
I have: Pumper carb set with all options. Carb air screw tool Valve adj tool set Lock set for either hawk or TBR7 which just needs a plug change. Couple large rear racks A few more first tune kits coming with me wife next week I’m a bit limited while here or faster postage |
06-11-2019, 09:06 PM | #48 | |
06-11-2019, 09:45 PM | #49 |
Got my pz30b a few days ago from nzbrakelathes, need to get it on my storm soon. Bikes stock right now, any advice on where to start with jetting? Might do an exhaust in the fall, right now what little time I have is going to wrenching on the storm and my vtx so I can hopefully ride them soon.
06-11-2019, 10:02 PM | #50 | |
That’s the same as hawk first tune I’d suggest that be ok as a starting point etc |
06-11-2019, 10:04 PM | #51 | |
06-11-2019, 10:12 PM | #52 |
Thanks guys. Taking Thursday off to take my daughter in to get her cast on her arm hopfully, rest of the day should be registering the storm, swapping the carb, putting the cruisers carb back together and maybe swapping the speedo in the storm if time allows.
Storm runs ok stock, bit of lean bog and its cold blooded. I'm looking forward to the pumper helping out with the bog and setting it a hair richer over all should help with the cold idle. Debating on if I should remove the pair system. |
06-11-2019, 10:16 PM | #53 |
You could, but I would wait until you put on a different exhaust or de-cat the stock one. The extra air pumped into the exhaust is to help keep the catalyst functioning properly in terms of function and in effect also help prevent it from "clogging" or fouling up.
06-11-2019, 10:20 PM | #54 |
Yeah keeping it hot and burned out. I don't mind it, the occasional lean pop it causes isn't a big deal as long as it doesn't cause any issues down the road. Pulling it off my cruiser while cleaning the carb because of the issues it causes with vacuum leaks. More involved system though with a bunch or lines.
06-11-2019, 10:50 PM | #55 |
[QUOTE=Cravin01;311704]That is a Cold start Pilot.. here's the vid...this is what I run in my PZ30 Pumper. link is in the description.QUOTE]
Thanks for the link. I eventually tracked the jets down on ali express awhile back. I am waiting for the jets to get here from China to see how they work in that "Russia Standard carburetor." I went round and round with the seller of the PZ30B and he eventually gave me $10.00 credit so I could get the jets for it. You got the "Russia Standard carb" with the rebuild kit and appears it came with that Keihin "cold start jet" but the picture of the rebuild kit shows another style pilot jet? Did the carb and rebuild kit both come with "cold start jets?" |
06-12-2019, 06:27 AM | #56 | |
[QUOTE=China Rider 27;311721]
This might help others ready this post. |
06-12-2019, 06:30 AM | #57 | |
Maybe think about using the single stock cable in to dial in the carb so it’s easier to remove etc Once you have the jetting right connect the twin cable dial in the pump In my mind this might be easier for some people etc and think it will cause less drama removing carb to alter jets etc Just a thought |
06-12-2019, 06:35 AM | #58 |
Those jets were a real pain to find at first, no one had them in their carbs at the time so it was a lot of fun finding them.
I can say they work great and have been in my bike for about 7 months. The tip is beveled unlike the stock one but screws right in and works fine.
07-07-2019, 01:42 AM | #59 |
So I tried to install my pumper after the voltage regulator fiasco and installing a digital cluster. Tired to adjust the pump timing only to find out it doesn't pump with the throttle. Even if you manually move the cam full travle it won't 18 out of 20 times. If you push the plunger down manually it will work. You can see in the video that a small amount of fuel Trickles out but no stream. The diaphragm is fine, the fuel paths look clean and I blew them out with carb cleaner. I tried adjusting the cam on the pump and that made no difference either. What am I missing?
07-07-2019, 02:04 AM | #60 |
That Pumper carb is nothing like mine, Mine shoots horizontally through the slide and not upward and you are right there isn't nowhere near enough fuel coming out. I would say the cable is not compressing the plunger far enough or you may have a restricted pumper port. it is not functioning right FOR SURE!
