05-01-2018, 07:37 AM | #46 | ||||||
My todo this evening:
Note: I've also got a 27.5 pilot on order for the VM 26 If all checks out, I'll order a spare CDI. Should I stay stock on that, or is there a 'better' CDI out there?
'17 Hawk / Mods: Mikuni 120/27.5, Airbox, .003 valve, 17f/45r, NGK Iridium, Aluminum Performance Exhaust |
05-01-2018, 07:47 AM | #47 |
Very puzzling. Everything seems to be checking out okay that you have done. When you did he compression test, did you have the throttle in open position? I would do the leak down test. Have you tried a 115 main? May be loading up on fuel.
05-01-2018, 08:36 AM | #48 |
Throttle was fully open. Is 150 PSI within spec?
I've tried with the factory 98, 110, 115, and 120 mains. Behavior is very similar across the board. I've gone ahead and ordered the All Balls Racing bearings, I'd rather those be quality anyway, and it's a good time to replace while the wheels are off. Has anyone replaced the coil/CDI with anything other than factory? Would it be worth going with a programmable CDI? (At this point, I've swallowed the pill to replace the cheaper components to weed out potential issues.)
05-01-2018, 09:02 AM | #49 |
Compression should be around 175-180 psi. But being that the engine is new and rings have not had a chance to seat it could be lower. Even at 150 psi you should still have good bit of power.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-01-2018 at 09:48 AM. |
05-01-2018, 09:06 AM | #50 |
FYI on the programmable CDI. It is a DC CDI and will require swapping of other electrical components to convert from AC to DC.
05-01-2018, 10:54 AM | #51 |
I recommend a stock-style CDI for now. After you get the bike running properly (so as to set a benchmark), you can experiment with racing CDI's.
05-01-2018, 12:06 PM | #52 |
might of been asked already but did you look into the end of the carb and move choke to see where open is? when i had oem 15/50 gearing i could do a wheelie in third gear but no it wont pull the wheel up by just twisting the throttle. you have a restriction or something bad with the electronics.
05-01-2018, 07:56 PM | #53 |
Just measured the Pickup/Exciter:
pickup - 180 ohm / .14 VAC exciter - .023 ohm and slowly climbs over time held / 35 VAC All of this seems low to the specs I've found, stator issue? Forgot to mention; not sure what it is, but looks like some kind of oil has found its way into the wire harnesses.. Maybe they had the bike sideways and leaked oil over, then fried the stator?
'17 Hawk / Mods: Mikuni 120/27.5, Airbox, .003 valve, 17f/45r, NGK Iridium, Aluminum Performance Exhaust Last edited by kyriakos; 05-01-2018 at 08:12 PM. Reason: +pictures |
05-01-2018, 08:14 PM | #54 |
Pictures
05-01-2018, 08:39 PM | #55 |
they may have put dielectric grease on the connections????
05-02-2018, 07:19 AM | #56 |
Budget Power Sports appears to be responding to warranty after threatening to stop payment... I've requested a new CDI, ignition coil, and stator.
I swapped back in the 15 front sprocket and loosened the chain, similar issue in no power around the 50 mph mark, and no particular 'bite' in any gears. New pilot jet arrives today, along with the wheel bearings. Also confirmed no drag on brakes, replaced brake fluids while I was at it.
05-02-2018, 08:16 AM | #57 | |
05-02-2018, 10:04 AM | #58 |
I'm really surprised that you still have this issue with all that done so far, my bike easily climbs to 60 before it drains out the last few MPH. This bike should too.
05-08-2018, 09:48 AM | #59 |
A bit of an update. The company shipped out new coil, stator, and CDI. Made each of those changes (1 at a time), but the performance increased only a slight amount.
I've ordered a leakdown tester (can't find one around here for smaller plug threads). This thing is driving me batty, pretty much all that's left are ring/piston/cylinder/head internals, and rectifier. The rectifier seems alright though, battery voltage goes up within range while running... I'm going crazy to get this thing resolved.
05-08-2018, 11:15 AM | #60 |
The leak-down test will let you know if there is an issue with the valves , cylinder or rings. If so, it sounds like a new parts or engine from the dealer.
