Old 04-08-2017, 08:58 PM   #46
BigWeld   BigWeld is offline
BigWeld's Avatar
Originally Posted by joker View Post
I'm assembling my green brozz also, having some trouble getting the seat off any tips? Also what things should I replace on the bike? Like (hawk chain)
Hey Joker, there's two vertical bolts that hold your tail light section in that require a 5mm Allen wrench or socket to remove (same size that you use on the side panels) once that assembly is removed, you'll see two nuts threaded on studs. Remove these with a 10mm wrench or shallow socket. Then, you can pull up on the rear of the seat and slide it back to remove it.
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf......
Old 04-08-2017, 09:19 PM   #47
Mag00   Mag00 is offline
Originally Posted by hertz9753 View Post
If it's like the Hawk seat you remove the single bolt from each side and pull the seat back and over the rear fender. Putting it back on is harder....
If it is like the Bashan Storm it will be similar. Remove the side panels and then you can get at the bolts for the seat.
Bashan 250 Storm
Husqvarna TR650
Honda Metropolitan
Be a Piggy!
Old 04-09-2017, 12:16 AM   #48
Kipper1012   Kipper1012 is offline
Kipper1012's Avatar
Still haven't figured out the seat lol moving onto the valves. Any one know what MM inlet and exhaust are supposed to be?
There are four Allen bolts holding on the rear tail light two of the bolts are at the very back of the tail light and the other two are behind the taillight on the inside of the fender
Once you remove those four bolts for the tail light pole off exposing the 210 mm nuts holding on the seat
2016 Green Bashan Brozz.
Old 04-09-2017, 09:17 AM   #49
Kipper1012's Avatar
Started the teardown to check and loctite everything
I found a lot of junk in the fuel tank so I'm going to be putting a inline fuel filter as a precaution after cleaning out the tank
Old 04-09-2017, 10:34 PM   #50
hertz9753's Avatar
That's a nice looking bike. When I used to do catering garages that had floors and walls like that did double duty for family gatherings and parties. Quite often they also had an area in the front or an upstairs with plumbing.
You seen some of the coolest things when you have been both a caterer and a Schwan's Home Delivery driver.
I'm sorry that I got off topic.
Old 04-09-2017, 11:33 PM   #51
MOTOXtreme   MOTOXtreme is offline
So for anyone in the know (calcune maybe) what is this engine a clone of? Anything in particular? Looking at maybe picking up some clutch disk just to have on the shelf. Also brake pads were mention earlier and someone said they were easily sourced on eBay. A link to those would be awesome. I'm not 100% certain which ones cross over to fit the brozz. Thanks.
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 04-10-2017, 08:31 AM   #52
Here's me setting up the ole Brozz. Put 50 miles on it this Sunday just starting the break in.
Brian
Old 04-10-2017, 09:38 AM   #53
Kipper1012's Avatar
LOL Yup Im ocd first thing I did was epoxy the garage floor when we moved in
Old 04-10-2017, 09:39 AM   #54
Kipper1012's Avatar
Nice video MOTO !
Old 04-10-2017, 09:41 AM   #55
Kipper1012's Avatar
I decided to trim that ugly plastic fender a bit. once i put a plate on it will serve as a mud flap anyway
Junk in the fuel tank
Old 04-10-2017, 10:42 AM   #56
I WISH my tank had looked that good lol
And yes I am definitely with you on chopping off that fender.
Brian
Old 04-10-2017, 07:29 PM   #57
Kipper1012's Avatar
LOL yea I saw your rusty mess.
Ive tried today to find a 1/8" inline filter locally and had no luck. Im going to try a 1/4 and replace the stock fuel line with a 1/4" line
Old 04-10-2017, 10:35 PM   #58
da4design   da4design is offline
da4design's Avatar
glad to see someone chopping off that fender..i am doing the same this weekend
Old 04-10-2017, 11:29 PM   #59
Kipper1012's Avatar
That thing was driving me crazy every time i looked at the bike
Im surprised more people haven't done it
Old 04-11-2017, 06:32 AM   #60
pistolclass's Avatar
just do some big wheelies.... it will come off all by itself.
brozz, green
