Old 05-17-2015, 09:39 PM   #46
Originally Posted by woodlandsprite View Post
...took advantage of the nice cooler weather today to go for a ride instead
Excellent choice!
Old 05-17-2015, 09:41 PM   #47
*sigh* I also now understand why people out here buy houses with lots and lots of garage space. We have a 3-bay garage, but the 3rd bay is somewhat truncated by a built in shelf and the fact that one of the walls has an angled wall - it was fine until we shoehorned in the 2nd bike :P Looking for ways to clear up space in that bay now especially since the other bike doesn't have luggage on it right now and we intend to get it a set of cases at some point! Not to mention the various other pieces of equipment I think I'm going to be acquiring to do maintenance
Sounds like it's time for a shed. In my municipality, we can build a 110 square foot shed without a permit, as long as it is a certain distance from property lines.
Old 05-18-2015, 01:43 AM   #48
Having never seen an RX3 up close, I can't be sure, but I suspect that a ratchet tie-down strap that secures the frame to the jack would allow a level lift.
That presumes the jack will slide under the bike.
I really don't think so, Weld. If the RX3 frame didn't have centerstand mounts, you could undoubtedly get a level lift. However, the protruding mounts for the centerstand make this task very difficult if not impossible. If you could somehow manage to get a level lift, it would not only be tenuous, it would also undoubtedly block access to the lower shock linkage.
In any event, I don't care to work that hard, especially when my Husky jack allows me to quickly, and securely lift either wheel.
Old 05-18-2015, 01:46 AM   #49
Of course, one can also install the CSC centerstand. However, I have heard it takes a good bit of upper body strength, and a strong back, to get the RX3 up on that centerstand. Since my aging back has seen better days, I would rather let my Husky jack do all the work.
Old 05-18-2015, 12:32 PM   #50
woodlandsprite's Avatar
Or I need to go buy another house with property that would be more suitable for a shed
The current house was purchased without all these additional vehicles in mind and it occupies a goodly portion of the lot, leaving hardly any room for a shed - ah the things I will have to keep in mind when we move and "downsize"
Old 05-18-2015, 01:46 PM   #51
Perhaps there's an RX3-specific opportunity to contribute. My 3 ton floor jack has a removable saddle, which leaves a hole in the frame. A pad could be fabricated that fits into the mounting hole, and provides clearance for the protrusions. The pad could also be covered with a rubber mudflap to protect the underside of the frame.
Old 05-18-2015, 01:49 PM   #52
My old '79 Yamaha XS650 Special was brutal to pull up on the center stand, until my buddy's Dad showed me the technique. He was a very slim man, and I couldn't believe how easy he made it look.
Not saying that you're not familiar with the technique, Spud. I'm saying that I wasn't.
I thought that I needed to pull from the bars to rock the bike onto the stand, but I actually needed to pull from the rear bar / carrying rack. It seemed so counter-intuitive to me, but it worked very well.
Old 05-18-2015, 01:50 PM   #53
Instead of 10x11, could you find space for a smaller shed, like 8x10 or even 5x10? That would at least allow you to get the mower, etc out of the garage.
Old 05-18-2015, 02:14 PM   #54
That's the method I used to pull my '79 Honda CB400T onto the center stand. I faced backward, and used my legs to lift the bike onto the center stand as I held the rear passenger grip. However, I was told matters are different for the RX3, so I declined to buy the center stand. Perhaps the person who told me of the difficulty was unaware of the proper method, but he seemed to be pretty knowledgeable. Perhaps someone else who owns the CSC center stand can either confirm, or deny the difficulty of using the stand.
Old 05-18-2015, 02:21 PM   #55
When I first bought my Husky jack, I fabricated a plate which I can substitute for the stock saddle. I tried using this plate, as well as several lifting stands, et cetera, to loft the rear wheel of my RX3. The method I used below is easily the quickest, and the most secure method I know to loft the rear wheel of the RX3.
Old 05-19-2015, 02:15 PM   #56
AZRider   AZRider is offline
I have a motorcycle specific jack from Sears Craftsman that I use on all my bikes, and with the addition of a block of wood have made it functional for the RX-3. The bike is stable,but adding a couple of tie down straps ensures a higher level of safety. It also lifts both wheels off the ground easily.
George
2016 CanAm Spyder F3-L
Old 05-19-2015, 02:39 PM   #57
Thanks for your input, George. That's a nice jack.
I see you have the rear support placed all the way behind the centerstand mounts.
Old 05-19-2015, 10:04 PM   #58
fishman10's Avatar
i have found that standing on the left side, i bend down slightly,enoughto grab the passenger footpeg mounting bracket with my right hand,,an with my lefthand on the handlebar .i can usually get it up on the stand on the second '' rock''...oh an of course my foot is on the centerstands ''tab'' to hold it on the ground. it works better for me than when i was trying to use the passenger seat grab rail,,as it was too high an i could not get any leverage.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 05-19-2015, 11:37 PM   #59
I had initially omitted the wood block, but the bike rocked on the two "legs" behind the center stand mounts. The block provides a more secure base.
George
Old 05-19-2015, 11:52 PM   #60
