Old 04-08-2016, 10:48 AM   #4891
Ron B   Ron B is offline
Ron B's Avatar
Originally Posted by Jay In Milpitas View Post
Ron, keep it mind it is a 250 and with all the gear a bit heavy, at that. At most I weigh 150 and mine happily runs past redline in 6th on the freeway so I have to watch the tach and back off. Running the stock 14/44 gears.
Most Cyclone owners are gearing lower (higher reduction) to make it more user friendly off road in the technical stuff. If you are seeking an ADV that will do both serious off road and also blast down the interstate all day, then perhaps a KTM 350 or something bigger will better suit you. Of course you're looking a twice the price if not more. Just don't want you to be disappointed.
just as long as it will do 60/65 im good. I have a HD ultra classic for trips.
Old 04-08-2016, 11:38 AM   #4892
detours   detours is offline
detours's Avatar
Originally Posted by AdventureDad View Post
...is the aftermarket skidplate worth the extra expense and hassle (related to oil changes) or is the stock one sturdy and protective enough to run mild off road on?
I have the aluminum skid plate and it's very nice. It provides excellent coverage against rocks thrown up by the tire and any impact from below. And it's a nice flat surface to lift the bike.
It also gives you about a half inch better ground clearance, because it conforms to the lower frame. You have to grind off the stock skid plate mounts to install it, so there's no going back to the stock one afterwards.
If I'm honest with myself, it's probably overkill for my needs. But I really like it.
Red 5 standing by!
2014 Ural Patrol
Old 04-08-2016, 12:08 PM   #4893
Lee R   Lee R is offline
Lee R's Avatar
I'm staying with the stock plate, the accessory is nice though.
I've only whacked one rock hard so far and that impacted the mounting point for the centerstand (i don't have one) which hangs down much further than the skid plate. If your going to hit something it'll be that first.
Logs don't seem to phase the stock plate if your don't hit them hard.
Old 04-08-2016, 01:12 PM   #4894
Juanro   Juanro is offline
Juanro's Avatar
I smashed a rock hard and it broke the front mounting tab from the lower cross member. If you're going to hit hard, it will break... and I'd rather have that break and not the engine case!
Old 04-08-2016, 01:19 PM   #4895
Lee R's Avatar
Juanro,
Did you weld it or replace with a CSC style plate?
Old 04-08-2016, 01:21 PM   #4896
Juanro's Avatar
I welded it. Once. I broke it again (Either I'm a very careles driver or the roads I take are hard, haha). Still with the stock plate, currently held by zip ties. Going to see a friend who's a better welder than me and fabricate a stronger mounting plate.
Old 04-08-2016, 01:29 PM   #4897
Lee R's Avatar
Careless or having more fun
Seems like a good idea to fabricate a new one, definitely post the pics when its finished!
Old 04-08-2016, 01:36 PM   #4898
Juanro's Avatar
I mean, the weak point is the mounting tab itself, not the plate, either stock or CSC style. The stock is dented but still perfectly good.
Old 04-08-2016, 01:46 PM   #4899
Lee R's Avatar
Maybe a point to reinforce for Zongshen. I agree the stock plate isn't bad and better than I've seen on bikes with double the price (KLR650).
Old 04-08-2016, 02:09 PM   #4900
I agree.
Old 04-08-2016, 02:34 PM   #4901
AdventureDad   AdventureDad is offline
AdventureDad's Avatar
Thanks for the replies ! I do like the looks of the accessory one, but for routine oil changes, the stock one is easier, based on what I see on the tutorials...is that fairly accurate? I'll be in soft dirt and some mud...not much into hopping logs, so the half inch shouldn't be an issue for me. If it becomes one, I'll pony up and buy it when it's on sale. Also, Spud, when you trimmed the handguards, you are referring to the extra aluminum backbone of it? The risers are going to be the 1 1/8? Also (and lastly), thanks to your tutorial on Taobao, I just picked up a great set of the Acerbis handguards for 20 bucks. Thank you for your hard work on this site.
Old 04-08-2016, 03:38 PM   #4902
Thanks for the replies ! I do like the looks of the accessory one, but for routine oil changes, the stock one is easier, based on what I see on the tutorials...is that fairly accurate?...
Yes, it requires less than a minute to loosen the 4 bolts and remove the stock skid plate.
... Also, Spud, when you trimmed the handguards, you are referring to the extra aluminum backbone of it?...
Yes, I trimmed the extra aluminum which extends toward the windshield. I used my angle grinder.
...The risers are going to be the 1 1/8?...
Yes, you need the 1-1/8" risers. I bought the 30mm Tusk risers.
https://www.rockymountainatvmc.com/p...ndlebar+risers
...Also (and lastly), thanks to your tutorial on Taobao, I just picked up a great set of the Acerbis handguards for 20 bucks. Thank you for your hard work on this site.
You're welcome. Thank you for your kind words.
Old 04-08-2016, 04:01 PM   #4903
Talk about some fast, and efficient answers!!! Thank you so much It is much appreciated.
Old 04-08-2016, 05:28 PM   #4904
rtking   rtking is offline
That's Spud. He's the man of Legend. Just wait until he starts pulling out schematics and referencing tutorials! This man clearly knows his stuff.
Old 04-08-2016, 06:22 PM   #4905
Ron B's Avatar
Is there a post on here with pics of peoples rx3 and their mods. Or can i just not find it.
