Old 09-07-2011, 04:39 PM   #31
katoranger's Avatar
I think the tractor supply will have the needed parts. I can make a bracket for a caliper.
Old 09-07-2011, 07:09 PM   #32
Let me know if you need it, and I'll box it up.
Old 09-07-2011, 08:05 PM   #33
katoranger's Avatar
I will. Will have to make a trip over to TSC to see what they have.
Old 09-09-2011, 01:20 PM   #34
katoranger's Avatar
Trip to TSC and was skunked. No #35 sprockets. No cart brakes.
Emilie started hand painting the frame after I laid the white base coat. :wink:
Old 09-09-2011, 09:51 PM   #35
What diameter #35 (or rotor) would you need?
Old 09-10-2011, 10:26 AM   #36
katoranger's Avatar
I think the sprocket is about 5-6 inches in diameter.
Old 10-06-2011, 03:51 PM   #37
katoranger's Avatar
Got some pink sprayed.
That belt clutch. I think I will need to cut the extra shaft portion off and turn it up side down so the pulleys are close to the engine fr belt alignment.
Buford getting some attention.
And watching the yard.
Old 10-07-2011, 01:18 AM   #38
Will the pulley work upside down? I've seen some ads for clutches (pulley or chain) that indicate they will work either way, but I don't know if they all will. It depends whether the weights are designed to move straight out or pivot once centrifugal force kicks in. Does it come apart?
Old 10-07-2011, 12:04 PM   #39
katoranger's Avatar
I think it will work. The weights pivot.
It is similar to this one and it says it can run both directions.
http://www.mfgsupply.com/m/c/H1P37.html?mv_pc=Froogle
Old 04-23-2012, 04:56 PM   #40
katoranger's Avatar
I found out that you press the pedal to make it go and let off to make it stop.
Also my Dad bought a seat for it. This project will resume in Kansas. I have all the parts packed up.
Also watching a vintage wheel horse with a mower.
Old 04-23-2012, 06:40 PM   #41
I love those older pics of your family and Bufford.
Old 04-24-2012, 12:57 AM   #42
That's cool! A deadman pedal is perfect for kids.
