Old 01-16-2010, 08:57 AM   #31
Baron   Baron is offline
Can anyone see the pics? I can.
Old 01-16-2010, 08:59 AM   #32
waynev   waynev is offline
I can't, did you do it through photobucket ?, that's what worked for me.
Old 01-16-2010, 09:04 AM   #33
No, I'll try that.
Old 01-16-2010, 09:05 AM   #34
TheRealWorld   TheRealWorld is offline
Still cant see them!
Old 01-16-2010, 09:19 AM   #35
Another try with the pics. please let me know if you can see them and if there's anythingelse you need to see a pic of.
<img border = "0" src = "http://i889.photobucket.com/albums/ac96/Baronvince/th_IMG_2528.jpg"/>
<img border = "0" src = "http://i889.photobucket.com/albums/ac96/Baronvince/IMG_2525.jpg?t=1263651168"/>
<img border = "0" src = "http://i889.photobucket.com/albums/ac96/Baronvince/IMG_2527.jpg?t=1263651458"/>
Old 01-16-2010, 09:27 AM   #36
I got the pics!
Old 01-16-2010, 09:46 AM   #37
Looks like the old fuel petcock was a vacuum operated one, someone must have suspected problems with it and replaced it with a generic one. First thing I would do is see that the vacuum hose connected to the old petcock is unhooked and plugged to negate a vacuum leak. A vacuum leak itself could cause it to not start. Another kind of scary thing on there is the usage of zip ties on the fuel lines... They can break without warning, especially if exposed to gas. The one fuel line doesn't really look like fuel hose either. I would take the hoses off and go to an auto parts place to match them up with proper fuel line and get some proper hose clamps. Here is a quicky instructible on carb cleaning to as I am not sure how much you disassembled them. Different carb I know, but the basics are the same for all of them .
http://www.instructables.com/id/Clea...-8-Easy-Steps/
P.S. the quads look good!
Old 01-16-2010, 09:50 AM   #38
Oh, when you get the 150 running, switch the back tires around. They are directional and are installed on the wrong sides right now. Just have to block it up and unbolt them then swap left for right and bolt em back up.
Old 01-16-2010, 10:03 AM   #39
X2 on MICRider's fuel line suggestion. I'll add that motorcycle fuel line is more easily found at a bike shop.
When you work with any bolt on the quad, use a good dose of Loctite 242 (blue coloured), including the wheels lug nuts.
Old 01-16-2010, 10:09 AM   #40
I'll replace the lines as you recommend. Should I remove the old petcock? How do I know what hose is the vaccum hose?
I'll pick up some loctite too.
Old 01-16-2010, 10:11 AM   #41
I believe the one line left hooked up to the old petcock is the vacuum line, it shouldn't have any fuel in that line. I would take it off and cap it to make sure that it is not leaking (drawing in air).
Old 01-16-2010, 10:20 AM   #42
If that's actually a vacuum line then i would have to believe that it is not a petcock but a fuel pump as all my snowmobiles use that setup.
Old 01-16-2010, 10:25 AM   #43
If you look close at the pic there are actually 2 lines coming out. one is clear/yellow - it goes no where, just hanging there. The black line connects to two other black lines (you can see this on the pic). Does the same apply? I'll try to get a pic of where those black lines go, but it's tight in there.
Old 01-16-2010, 10:29 AM   #44
Actually here they call it a fuel valve ( petcock ) http://www.scootertronics.com/fuelvalve.html but they say for better performance to use the mikuni fuel valve ( which is actually a fuel pump ).
Old 01-16-2010, 12:38 PM   #45
Something wasn't making sense so I double checked the 90 for spark and there's NO SPARK. I'm not sure if I confused the two bikes before or what, but I'm not getting a spark. I tried the test where you stick the light tester in the plug wire too. I got no light, but I could be doing it wrong.
Does it sound like I need a new plug wire? Or could it be something more serious?
I'm usung a brand new NGK plug, so that's not the problem.
