11-16-2009, 06:40 PM | #31 |
FWIW the Zong records miles, not km.
I think the tank is about 2 gallons, 70 MPG or so would be about 100 miles to reserve, so you seem to be in the ballpark. Mine did about 75 until it got creamed as well. :? The important thing id it will do 60 easily.
Happy to serve. |
11-16-2009, 07:08 PM | #32 | |||
Ordinarily, I used to ride about 125 miles before I reached “reserve†on the stock fuel tank. However, if I was riding wide-open-throttle against a stiff Idaho wind, I might only ride 90-100 miles before I reached “reserve.†Quote:
I am very glad your Zong is running well, Dave! If you change the engine oil frequently, and check the valve clearances according to the schedule in the Owner’s Manual, your Zong should last for many miles. Spud
11-16-2009, 07:11 PM | #33 | |
11-16-2009, 08:01 PM | #34 |
Are you sure the odometer/trip meter records miles? I tested that today.
I was driving down a highway that had mile markers and i checked it twice. both times the bike turned a full digit before the mile marker would arrive, so I assumed that it was clicking over about every .62 of a mile or 1 kilometer. At each point i reset the trip meter to zero, and observed the odometer so i am pretty sure its kilometers, or close to a kilometer reading. 8O FWIW i am running stock tires. Also why would they have the primary speedometer record in kilometers and miles secondarily, underneath? AND have the odomter use miles? doesnt make sense. i mean maybe mine is not recording correctly, but thats what i am seeing. Dave |
11-16-2009, 08:10 PM | #35 |
also, the last tank we got 109 on the odometer for a full tank before we had to hit the reserve. Generally my son says, for every 100 needs to get a tank of gas.
We run it on premium only. |
11-16-2009, 09:42 PM | #36 | |
If you get the time, please try this experiment. Measure a mile on a country road with your car's odometer; then travel the same route with your Zong. I bet your Zong's odometer records something like 1.1 miles, instead of the 1.6 miles you would expect if it were recording kilometers. Also, the reading on your trip odometer when you refill the gas tank seems to indicate it is recording miles. If your odometer is truly recording kilometers, you are not getting very good gas mileage. Spud
11-17-2009, 11:58 AM | #37 |
I agree with Spud. Even my Gold Wing will read a little less than 1.1 per mile. All speedos are calibrated a little optimistic to help prevent accidental speeding. I also suspect my Zong's read a little faster than that, but never had the chance to check it. I's run the bike over a 5 or 10 mile course of marked highway and divide to get a better idea of your odometer. Mine is miles, other Zongs I';ve seen and heard of are also miles. Jersey miles may be different though. I'm from Joisey.
Happy to serve. |
11-17-2009, 01:08 PM | #38 | ||
For example, here is a thread from the TW200 forum complaining of inaccuracy in the TW200 speedometer. If you visit other forums, you will find many posts with a similar theme. http://tw200forum.com/forums/48930/ShowPost.aspx Quote:
When I first got my Zong, I measured a 1.0-mile course with my car’s odometer; I then rode the same distance with my motorcycle. As with Doc’s Gold Wing, my Zongshen’s odometer recorded a little less than 1.1 miles for the distance traveled. My speedometer is also “optimistic†by ten percent. After reading many internet posts on this subject, I assume this inaccuracy is common for most motorcycles; therefore, I accept it as “normal.†:roll: I always subtract 10% from the speedometer reading whenever I want to judge my true speed. :roll: If you want an accurate speedometer/odometer, you usually need to purchase an aftermarket, digital unit. Apparently you must do this even if you own an expensive Japanese, or European motorcycle. :roll: Spud
11-17-2009, 01:58 PM | #39 |
A GPS would be a good way to go also.
Everything on the Wing is the highest quality, and priced accordingly. 8O . It is designed/engineered for 300,000 mile service, and has no problem doing that with a minimal amount of maintence. Nice bike. The Wing's speedo is digital, but drives an analog readout. It can be reprogrammed to remove the built in 'error' but it's not something I bother with.
Happy to serve. |
11-18-2009, 02:26 AM | #40 |
The conspiracy theorist in me thinks that the "optimistic speedometers" go hand in hand with "optimistic odometers". There was some press about this in cars recently, and it dealt with the car displaying more overall miles than were actually travelled. I think it was Honda that settled out of court, but I'm not sure.
It's brilliantly devious on part of the manufacturers when you think about it. The warranty expires sooner, and people ultimately replace their vehicles sooner. It doesn't make alot of difference to one consumer, but when you factor in several million automobiles...
11-18-2009, 02:33 AM | #41 | |
How it applies to motorcyles with very little warranty I'm not sure.. |
11-18-2009, 02:41 AM | #42 |
As a former engine builder, do you believe the claims about 5W20 contributing to an early demise?
I believe that 5W20 frees up horsepower (as proven in a recent Car Craft article). I also believe that the oil pump and oil filter pressure relief spring in a given application is tuned for a specific weight, meaning that you shouldn't change weights arbitrarily. Not sure if oil feed holes are similarly matched to oil weight and viscosity.
11-18-2009, 03:18 AM | #43 | |
The conspiracy club would have you believe they've selected this oil for that reason, to reduce the internal mass of thicker oils therefore to pump the engine power numbers up for marketability reasons, but cutting short the engine life. (thinner oil, less protection etc) The folks claiming they've always used 20/50 in their V8's and won't stop now just have their heads up their butts. These new engines are not much like the 350's of old. Oil passages are narrower and longer, lifters are smaller. These engines will plug up with thick oil, essentially starving it because of too slow drainback. Then who's the smart one? You're right about the filters and screens as well. I really don't see any practical reason to questioned the mind of an engineer who designed an engine that makes 350HP, in stock production on his choice of the best oil. Who are you kidding? |
11-18-2009, 03:45 AM | #44 | |
My automobile speedometer and odometer are both accurate. However, it seems that almost all motorcycle speedometers are "optimistic." I know that my Zong's odometer records "optimistic" miles; I wonder if "optimistic" odometers are also the rule for most motorcycles? :?: Spud
11-18-2009, 10:48 AM | #45 |
JUST TO PUT IN MY 2 CENTS I CHECKED MY SPEEDO AGAINST A SCHWYNN BICYCLE SPEEDO AND WHEN MY ZONG SAID 60MPH THE SCHWYNN SAID 49.5 GIVE OR TAKE I FIGURED THE TIRE DIAMETER SEVERAL TIMES TO MAKE SURE I HAD IT RIGHT. WITH THAT BEING SAID IF I RIDE AT A COMFORTABLE CRUISING SPEED I SHOW AROUND 117-125 MILES T0 RESERVE BUT IF I RIDE IN A HURRY LIKE I NORMALLY DO I GET AROUND 104 MILES TO RESERVE. SOUNDS PRETTY CLOSE TO WHAT YOU GUYS ARE REPORTING.
SHAWN
my help may not be the best but it is free+-Seek ye first the kingdom of GOD |
