Old 05-05-2009, 10:36 AM   #31
KentuckyDonkey   KentuckyDonkey is offline
Yous guys have me convinced that this will indeed work! (Seeing that these things work on revolutions per minute/second rather than on time intervals).
This is great!
Old 05-05-2009, 12:12 PM   #32
LynnEdwards   LynnEdwards is offline
KD you're almost there. Revolutions per second *is* a time interval measurment. One is the inverse of the other, and both are just different ways of saying the same thing.
If I buy 5 hamburgers for a dollar, I can take the inverse and say that I paid 1/5 of a dollar per hamburger (or 20 cents).
If the quad wheel is rotating at 5 revolutions per second I can take the inverse and say that the wheel is turning at 1/5 of a second per revolution. Seconds per revolution is a time interval measurement.
To follow an example all the way through, if the wheel is 11.46 inches in diameter then the circumference around the wheel is 36 inches or 3 feet (circumerence = pi * diameter).
At 1/5 second per revolution (or 0.20 seconds per revolution) the speed is:
Speed = distance/time = 3 feet / 0.20 seconds = 15 feet per second.
To convert to miles per hour:
(15 feet/second) * (3600 seconds/hour) / (5280 feet/mile) = 10.23 miles per hour.
Old 05-05-2009, 12:25 PM   #33
Yes, Lynn- half a dozen of one and six of another
I was instead initially thinking that these things worked off of the principle of actually measuring the time between passes of the magnet, rather than the given number of revolutions within a set time. (In the latter, then, as you say, it is just necessary to calibrate to the outside diameter of the wheel to determine how far it travels per revolution, and viola[sic]!!)
Now for the intricacies of mounting: How far can the the magnet be from the sensor?
Old 05-05-2009, 01:03 PM   #34
Cal25   Cal25 is offline
Pretty close. I would guess about a quarter of an inch.
Old 05-05-2009, 03:51 PM   #35
forchetto   forchetto is offline
If you find 1/4" doesn't work either try and get it closer or get one of those rare earth magnets that are only about 3/8" wide but incredibly powerful.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 05-05-2009, 04:26 PM   #36
Thats what is on mine. It is the head of a 6mm capscrew that is screwed into a hole i drilled in the brake rotor. pick-up sensor is ty-wrapped to the fork. Too far away and no signal. All in all it is very easy to do and dont see why a bike speedometer would not be similarily easy to adapt to an ATV.
Old 05-05-2009, 09:38 PM   #37
Mobus   Mobus is offline
OK, sorry it took me so long, but here are the pics I promised earlier in the thread. I made the mount for the pickup out of aluminum. I made a template out of cardstock first so I could get the size right before cutting and bending the aluminum. You can see the magnetic bolt I made through the brake disc. I used a nut on the bolt to space it up/out towards the pickup. My disc had extra holes so no drilling was required. I drilled a 1/4" hole in the bolt head and when I dropped the 1/4" neo magnet in it just sucked itself in, and it's NOT coming out, LOL. Works great.
All the pics are from the rear of the atv looking forward just at different angles.
http://i188.photobucket.com/albums/z...V/100_1493.jpg
http://i188.photobucket.com/albums/z...V/100_1492.jpg
http://i188.photobucket.com/albums/z...V/100_1491.jpg
http://i188.photobucket.com/albums/z...V/100_1490.jpg
and the bolt:
http://i188.photobucket.com/albums/z...V/100_1495.jpg
'08 Haili Icebear 110cc
'05 Roketa RTB-90x
'71 Honda Z50A Mini-Trail
Old 05-06-2009, 02:42 AM   #38
...Now for the intricacies of mounting: How far can the the magnet be from the sensor?
I've been doing some reading on magnets and giving this some thought now that I'm anxiously waiting for my speedo to arrive in the mail. Those high strength exotic magnets are definately the way to go. But if I want to maximize the minimum distance needed between the magnet and the sensor I think I need to do some things a little different than has been done so far:
1) The magnet should be mounted in a non magnetic holder (such as a brass bolt). If the magnet is placed in a steel bolt the majority of the magnetic flux will be bent away from the gap between the magnet and sensor and will be swallowed up by the much more permeable steel bolt. The sensor will then see a much reduced magnetic field as it rotates past.
2) The magnet should be longer than it is wide, and have the north/south poles at the long ends. This puts the far pole much further away from the sensor then the near pole. If the magnet is much longer than the gap between magnet and sensor then the magnetic flux falls off the near end as the inverse square of distance (classic monopole model). If the magnet is short compared to the sensor/magnet distance the flux falls off as the inverse cube with distance (classic dipole model). In between magnet lengths fall somewhere between inverse square and inverse cube.
So much for theory. I'm planning on chucking the quad sprocket and magnet holder(s) in my lathe which can go down to 2 revolutions per second (120 RPM). I'll mount the sensor in the tail stock and use the tail stock feed to measure the maximum sensor distance for various magnets and various holders.
None of this is really necessary of course. I just want to know what the maximum feasable distance is.
Old 05-06-2009, 08:43 AM   #39
Good info there. I think the capscrew that my magnet is on is made of stainless. I suppose the preformance would be similar to the brass.
Old 05-06-2009, 10:50 AM   #40
2) The magnet should be longer than it is wide, ......
Don't ask me why, but that just seems so naturally true- like one of those things that ya "just know".
Heh...the lathe experiment should yield some great results!
Old 05-06-2009, 08:38 PM   #41
yozalo   yozalo is offline
I'm lost, I don't know what you are talking about. I'm not that mechanically inclined. Can some one please tell me step by step to do this mod. Any help is appreciated.
Old 05-07-2009, 01:26 AM   #42
My speedo arrived today. Did some preliminary quick and dirty tests.
The sensor sensitivity does not seem to change with how fast the magnet is moving past the sensor. It even responds to the magnet creeping past the sensor (the speedo turns these little wheel icons on the display when it detects signal from the sensor).
Some very sloppy tests between long versus short magnets showed that long magnets worked over a longer distance between magnet and sensor, but not nearly as much as I thought it would. This test is sloppy because I have no accurate way of comparing one magnet's overall strength over the others. For the test I did try to match up long and short magnets that pulled about the same on a steel plate.
Putting the magnet in a brass bolt holder rather than ordinary steel one made a significant difference. With the steel holder the sensor/magnet distance had to be less than 1/8". With the brass it worked fine at 3/8". This test is more accurate because I'm using the same magnet in both holders.
The magnets I used were wimpy. The one that came with the speedo was also wimpy. I will go buy some mch stronger rare earth magnets when I actually do the installation.
The cable between the sensor and the display was only about 2.5 feet. I cut it in two. There are only two wires inside. You can add as much wire as you need, and it doesn't matter how you hook them back up. I tried it wired both front and back and it worked fine.
Old 05-07-2009, 01:33 AM   #43
Yozalo, don't let the technical details get you bogged down. Look at Mobus' pictures on how he mounted his speedo, use a brass bolt instead of steel (it is easier to drill,anyway), and use the most powerful small magnet you can find. When you mount the sensor get it as close as you can to the magnet without hitting and your speedo will work fine.
Old 05-07-2009, 04:58 PM   #44
You can purchase them from here:
http://www.dealextreme.com/details.dx/sku.5964
http://www.dealextreme.com/details.dx/sku.5962
Old 05-11-2009, 12:41 AM   #45
I installed my schwinn bicycle speedo. It works great. Here are some pic's showing how I did it. Sorry about the muddy quad. I've been helping my neighbor install a new lawn. We've both been using our quads to move stacks of rolled sod around:
I mounted the display on a bracket I had already added a while back when I installed a horn. You can see the bracket and horn button below.
The following two pics show the pickup sensor and the magnet holder:
The magnet holder is made from a hunk of 3/8" scrap aluminum bar which is bolted to the axle drive sprocket with two 10x32 stainless screws and nylon insert locknuts. I epoxied a stack of three exotic high strength magnets in the center bore of the holder. Tests showed the pickup coil saw these magnets reliably out to more than 5/8", though it turns out the simplest mounting scheme for my quad put them much closer at around 3/8". I would have had to go out of my way to make that distance greater.
It was not possible for me to use the brake rotor as Mobus did. I have a funny bulge near the center of the rotor that makes this impractical. The drive sprocket works fine. The steel isn't hardened and drills easy. If the chain comes off then my sensor is probably toast, but a new speedo is cheap. In the hundreds of hours on my quad I never had the chain come off yet.
The pickup sensor is mounted on a plate made from a scrap hunk of 3/16" thick XX grade phenolic. Aluminum, fiberglass, or steel would work just as well. Note how I have the sensor mounted 90 degrees out from it's normal orientation on a bicycle installation. It doesn't seem to matter as far as I can tell. Rather than use the tie wraps provided I tied it down with multiple knots of lacing cord, then glued it in place with 3145 RTV silicone rubber. Epoxy would work too.
I used two existing holes on the axle hub to mount the sensor plate. To design the sensor bracket to fit these holes I used Mobus' technique of using "cardstock" to model the needed bracket until it fit the complex contour of the axle hub and mounting holes. You start off with a piece of cardboard and whittle it down with a pair of scissors to make it fit. When you whittle too much just trace it to a new piece of cardboard adding more area as needed and start again. The picture below shows my cardstock template and a semifinished bracket. The other stuff is work in progress to make the second speedo. My next door neighbor has exactly the same qaud as I do and wants a speedo on his now too.
Next picture shows the wire routing up the swing arm. Note that the stock speedo cable is way too short. I cut it and added about 4 feet of cable to extend it to the handle bars. When connecting up the added cable, polarity doesn't matter.
To measure and calibrate the speedo to my wheel circumference I compared two different methods:
1) I used a tape measure to measure the circimference directly. I got 4 feet 8 inches, or 56 inches, or 1422mm
2) I used Katoranger's paint the wheel and mark the concrete method and got 4 feet 7 1/4 inches, or 55.25 inches or 1403mm
This is an error of about 1%. Either one is close enough for my requirements. If I'm going 30 miles per hour I don't much care if my speedo tells me it is 29.7 or 30.3 MPH.
I've tried this on the street in front of my house. It will be at least four weeks before I can try this thing on real terrain. I have a new project which will keep me working at home on the weekends until then. If I find anything flakey I'll report back.
All in all this was an easy install.
Lynn Edwards
Note: Edited to give proper credit to Mobus earlier posts.
