03-23-2023, 05:24 PM | #31 |
Was rainy all day today so couldn't go out at all. I didn't want to ride it how it was. Like I said it immediately causes the spark plug to go black. Even once I put the new one in and turned it on for 30 sec with a couple light revs. I turned it off and pulled the spark plug to check and it was already getting black. So I have the original spark back in (after I wiped off the black carbon). Gonna go thru and check battery and electrical connections tomorrow.
The Bearded Vagabond YouTube Channel |
03-23-2023, 05:38 PM | #32 | |
Black spark plugs are a sign of too rich. And you can hear it in the video. It floods with fuel and then it starves and then it floods again and then it starves.
2020 Lifan x-pect |
03-24-2023, 05:51 PM | #33 |
Ok I have figured out the wierd stutter. It was actually a throttle cable issue. I basically went thru everything disconnecting and reconnecting til I figured it out. So it now idles normalish. However I now have 2 issues. 1 is that after 30sec to a minute it turns it's self off after slowly losing it's idle. The second is when I turn the handlebars left it is pulling the throttle cable and revving. I can figure out a way to loosen the cable and I don't see it really catching on anything. Also,i wasn't sure about the higher pitched "clicking" like sound from the engine. Any and all advice is appreciated. New video to show what I am talking about.
03-24-2023, 09:06 PM | #35 |
I’m glad my guess was not it. I’m also glad you got it figured out.
strange that it was giving fuel and not, giving fuel then not and giving too much fuel and making the spark plug black from a throttle cable situation. But awesome that it’s better. now it’s really time to go for a ride. Ha ha. I ran mine sounding like that and stalling at idle if I didn't give it some throttle for 5000 miles. you’ll have to reroute that throttle cable in some way so that it doesn’t stretch like that or pull. But xlsior is right. when I did my valve adjustment at 5000 miles, it ran much more smoothly. it sounded exactly like yours and died out like yours on idle from day 1. Same thing. I just got used to it and rode it like that. but after the 5000 mile valve adjustment it stopped doing that. And it sounded much more smooth. It’s definitely time to go for a spin. No harm done there.
2020 Lifan x-pect |
03-24-2023, 09:41 PM | #36 | |
I recognize that noise, definitely the valves need adjusting. I've checked and adjusted mine 4 times in the first 3000 miles, each time one or both needed adjusting. I had the same issue early on with the throttle increasing when turning the handlebars. Check how all of your cables, brake lines, etc are routed and assume they didn't route them the best way. In your first video it didn't appear all of your cables were routed in the least binding way. I've added a few zip ties and electrical tape here and there to make sure everything stays in place and there are no exposed wires. I think the idle will get better with time, my bike has died at idle 3 or 4 times, but not anytime recently.
2022 Lifan KPX 250 |
03-25-2023, 03:01 PM | #37 |
Thanks everyone for the help. Got the throttle cable rerouted and seems good now. Also not dying on idle or rev anymore. Still got the clicking but it got way to windy to keep working. One of the gusts shot my wrenches across the driveway. Supposed to be sunny and nice tomorrow so will finish it up and test ride it finally tomorrow.
You all are so damn nice and helpful here. Can't thank you all enough. In a weird way I am glad I had so many initial issues as it is allowing me to really dive into learning the bike.
03-25-2023, 06:19 PM | #38 |
Was the engine cold when recording the 'noise' ? tappety valves tend to dampen out when up to running temperature...
03-26-2023, 06:18 PM | #39 |
All fixed and rode the first time today. Everything is working good. I do however really hate the clutch and brake levers. Has anyone replaced these on the KPX 250 yet? If so which ones did you get. Do you think ones that will fit the X-pect will work?
04-05-2023, 04:20 PM | #40 |
How has your experience with bike been so far? Did you get any recommendations on levers?
04-07-2023, 12:43 PM | #41 |
Finally got out on the road with it today for a little bit. Drove well, just HATE the levers. I didn't get an answer on them so I took some pictures of the levers on the bike and then just ordered some on Aliexpress that looked like they would work. I will post which ones after they get here and I see if they fit or not. I also did attempt to wrap it with green carbon fiber looking vinyl. It didn't go great so I am gonna end up pulling all that off and just spray painting it with Kawasaki 777 Lime Green (just the white pieces). I don't think I will be able to wrap it and it look as good.
05-06-2023, 03:39 PM | #42 |
Been loving the bike so far, except the seat (and the mirrors but I mentioned that earlier). I find that after 45min or so my butt is hurting. By 1 hr riding is no longer as fun. So gonna get a cushion. I have seen the maddog seat cushion recommended. Before I order that one has anyone tried different ones they may recommend?
05-07-2023, 06:17 AM | #43 | |
I have had both a DR 650 and an Xr 650 and my butt was killing me after an hour or so. After some long rides on the KPX, I really took notice of how comfortable the seat was. |
05-12-2023, 01:00 PM | #44 |
Is this the correct size to adjust the valves on the KPX 250? I have been trying to use tools not made for it and it is a pain in the a**. Wanted to avoid ordering the set of 3 if I could save the money and get just the 1 right size. Thanks in advance.
https://www.amazon.com/gp/product/B0...NJJP1U27&psc=1
05-12-2023, 01:23 PM | #45 | |
Tags |
lifan kpx 250, motovlog, txpowersports |
