12-06-2022, 04:59 PM | #31 |
I use T4 on my hawk. I have 500 miles on it and have changed the oil 4 times. Never ran the factory oil in it. I also bought a magnetic drain plug after the second oil change and it has had a good bit of sludge on it during oil changes.
12-06-2022, 11:53 PM | #32 |
Now I see why people refer to the factory oil as shipping oil. I'll be replacing it before the first startup.
Tips: Upon receiving your vehicle (and after reviewing the video) we recommend that you heed the following tips: 1. Perform your first oil change by replacing the Engine oil with 10W40 motor oil prior to starting. X-Pro Owners quick guide DB-K012 (Templar) owners manual
22 Templar 250 |
12-07-2022, 01:49 AM | #33 |
Metal in the oil is a normal side effect of the break in process. The bigger shavings aren't uncommon either as almost every Hawk owner can attest. I found more than a few in my screen after my first oil change. It's potentially swarf from machining and manufacturing but it can also come from the gears in the transmission which are often rough finished and "wear in" into one another.
12-07-2022, 07:51 AM | #34 |
When I got my TT250 last year, I didn't know any better (despite going over much in these forums) and didn't change my oil until I think 300-400 miles. It was pretty dark, and my filter had minimal metal shavings, but I've been on the ball ever since just using Valvoline 10W40 synthetic. Got 5k+ now and still smooth, so something went right, and here's to 15k more!
