Old 04-06-2017, 12:28 PM   #31
Originally Posted by Kipper1012 View Post
Yup im going to do it when i get home. Im going to take the forks completely off and drain them rather than mess with the bottom bolt.
I'm sure you know this already but loosen the upper tree clamps first, then loosen the caps, then loosen the lower tree bolts and drop them out. Be careful, sometimes they zip right on out in a flash.
Old 04-06-2017, 01:19 PM   #32
Kipper1012   Kipper1012 is offline
Kipper1012's Avatar
Thanks for the tip . I'm a mechanic but I've never touched a bike before
2016 Green Bashan Brozz.
Old 04-06-2017, 07:52 PM   #33
da4design   da4design is offline
da4design's Avatar
so very true! that happened to me today! i managed to get the oil changed out, the top bolt stripped when i was tightening ..and i wasn't cranking them down either. i noticed those bolts are short anyway so a trip to lowes and now both are replaced with longer bolts and all is good
Old 04-07-2017, 10:43 AM   #34
Glad you got it worked out.
Loosening the top clamp first will take the "squeeze" off the top of the fork tubes so you can loosen the caps.....but leaving the bottoms tight until you get the caps will hold them in place so you can wrench on it. Those USD forks can ZOOM right out of the trees when they're loosened. I've had one hit the ground the second I twisted the bolt on the bottom tree.
FYI-Those tree clamp bolts only take about 12 ft lbs per 8mm bolt spec.
Old 04-07-2017, 02:04 PM   #35
Kipper1012's Avatar
Well long story short after 1 day of searching local nut and bolt suppliers and bike and moped shops. I managed to find a front axle bolt for my Brozz.
Yes i did file a claim with superior power sports BUT I Dont want to wait for the claim to ride my new toy.
So if anyone else needs one it is a M11.8x265 axle bolt from get2itparts dot com
I was skeptical since Ive never heard of a M11.8 Only a M12. But after calling them he did confirm the bolt is a 12mm OD bolt
Old 04-07-2017, 02:10 PM   #36
Kipper1012's Avatar
And I managed to straighten the bent axle bolt with a hydraulic press enough so I can atleast move the bike around.
And damn if I'm not tempted to putt around my street. I'll try and keep myself busy until the new bolt comes in though
Old 04-07-2017, 02:20 PM   #37
MOTOXtreme   MOTOXtreme is offline
You did a bang up job straightening that. I think you'd be fine With using that bolt until the new one arrives. I've enjoyed out venture together. I'm still taking my time going over mine. Tonight's agenda is rear tube, more loctite(ing), drain Chinese oil, etc. May even get her fired up.
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
Old 04-07-2017, 02:32 PM   #38
Kipper1012's Avatar
Thanks ! I think it will be ok too but im going to err on the side of caution.
I still have to go through every bolt also and change the brake fluid, engine oil.
Plus im still waiting on parts to arrive. Shift lever brush guards etc.. Im just taking my time.
Old 04-08-2017, 07:56 AM   #39
Kipper1012's Avatar
Got a call last night from Superior power sports they said my damaged parts should ship out Monday. Other than the miscommunication about the tracking number I am very pleased with them.
Old 04-08-2017, 12:29 PM   #40
joker   joker is offline
I'm assembling my green brozz also, having some trouble getting the seat off any tips? Also what things should I replace on the bike? Like (hawk chain)
Old 04-08-2017, 12:45 PM   #41
goat67   goat67 is offline
goat67's Avatar
To get the seat off you need to remove the tail light then you can get at two nuts that hold the seat on
2016 Brozz
Old 04-08-2017, 02:34 PM   #42
Still haven't figured out the seat lol moving onto the valves. Any one know what MM inlet and exhaust are supposed to be?
Old 04-08-2017, 02:44 PM   #43
Merlin   Merlin is offline
In .05mm out .08mm
Bashan Blaze
Old 04-08-2017, 03:49 PM   #44
Ariel Red Hunter's Avatar
Good idea. That bolt is stressed from the bending both ways. While it probably would be fine, I wouldn't want my life depending on a stressed bolt...ARH
Old 04-08-2017, 07:23 PM   #45
hertz9753's Avatar
If it's like the Hawk seat you remove the single bolt from each side and pull the seat back and over the rear fender. Putting it back on is harder....
brozz, green
