04-04-2017, 05:40 PM | #31 |
The only issue I had with ATF back in the day was it foaming under heavy abuse, like motocross, and pumping up the forks. I ended up buying fork caps with Schrader valves in them to release the pressure. It's why I run Bel Ray, out of habit.....not that I ride anywhere near that level anymore. I'm sure ATF would work just fine.
04-04-2017, 09:14 PM | #32 |
I know the Qlink inverted ones required 330ml. I think Spud was using that much also on his Zong 200 but I can't find the posts easily.
04-04-2017, 10:12 PM | #33 |
04-05-2017, 10:12 AM | #34 |
Indeed. I just did mine last week. I dumped out 320 figuring there was still about 10 inside and clinging to everything. Refilled with the same 320 and works like a champ! Did the same to the TT250 inverted forks.
04-05-2017, 03:14 PM | #35 | |
05-12-2017, 11:36 AM | #36 |
How much oil goes in the hawks forks ?
05-12-2017, 11:43 AM | #37 |
200 ml. I put 210 o firm it up a little.
05-12-2017, 01:58 PM | #38 |
So all I do is remove bolts from bottom of forks let it drain . Replace bolts and then refill with 200ml of fork oil . I've been reading about people haveing trouble getting bolts back in . Did you hawk give you any trouble ? I just wanna make sure I gotta grip on what I'm doing lol
05-12-2017, 02:06 PM | #39 | |
05-12-2017, 05:20 PM | #40 | |
they will drain them.. getting them out or back in can give probs as the damping rod may start to turn with the bolt... " do you feel lucky ?" Take them out of the bike tip the up and drain the oil out though the top... ..
05-12-2017, 07:23 PM | #41 | |
I have not done the job but I will drain the motor oil then lay it over and drain that fork from the top. Knowing my luck I would f#$% that bottom fork end up for sure. Taking a ride first to heat the fluids for easy drain.
05-12-2017, 07:47 PM | #42 |
Pete is right, there is no need to remove the dampening rod bolt to drain them. Turn them upside down, let as much flow out on it's own as possible, and then cycle the tube up and down a few times to help push as much out that still might be trapped as possible.
If you want to remove said bolt so you can effectively flush all of the old oil out, buy yourself some extra ATF, then simply fill and drain them a couple of times, cycling the tube up and down to work out the air, and that should flush them fairly well. Then don't neglect your future fork oil changes. You would be amazed at how fast that oil gets dirty. If you, for whatever reason, decide to take the dampening rod bolt out, a cheap and very effective way to hold it still while trying to remove said bolt, or tighten it back down, is go buy a wood broom handle at the hardware store with the tapered end (not threaded). Usually that tapered wood end will wedge into the opening of the dampening rod just enough to get them tight/loose, Then just make sure to snug them up once the forks are back together with springs and caps installed. Also, do yourself a favor, and don't over tighten those dampening rod bolts. They don't need a billion pounds of torque to do their job.
04-25-2019, 05:38 PM | #43 |
Have to ask...in the spirit of making life easy and thinking about how I service my automobile with various fluids etc.
Could one simply use a fluid pump from any automotive store with a thin enough hose, gently run her down the fork tube to the bottom, inside the spring and pump out ? Maybe it's not possible, but if it is, it just seems so deliciously easy. King |
04-25-2019, 06:55 PM | #44 | |
04-26-2019, 09:54 AM | #45 | |
