Old 08-26-2016, 07:19 AM   #31
LunaTech   LunaTech is offline
LunaTech's Avatar
Originally Posted by hertz9753 View Post
You are that guy. Only two of us have tried the tried the K&N so far.
The weather stripping is used so the retainer can push down on the filter and the filter seals on the airbox.
Yep, I just used the square stick on weather stripping on mine. Great minds think alike
Old 08-26-2016, 03:47 PM   #32
Ariel Red Hunter's Avatar
Hawkie-Talkie
A word about single lobe cams and valve timing. Because the engine uses only one cam lobe does not mean that valve timing has to be concentric, e.g. 20-70 70-20. It depends on the shape of the valve lifter foot, and the location of the lifter shaft. For example, My Ariel Red Hunter had timing of 18-68 & 63-23. For those few of you who don't know what that means, it is inlet opens before TDC, inlet closes after BDC & exhaust opens before BDC, and exhaust closes after TDC. Just plug the numbers in, and you will know. I've not, so far, found a valve timing diagram for this neat little engine. If someone knows, share it with the rest of us. Timing should be a little bit more radical for the Hawk engine because peak power is at 7500 rpm. My NH (350) Red Hunter peaked at 6250 rpm.
The chassis: The Hawk has a rugged steel frame, with a 3.00 X 21 inch front wheel and tire, and a 4.10 X 18 rear wheel & tire. They have disc brakes front and rear. For whatever that's worth. In my opinion, not much, on a primarily off-road bike. They have quite good, but not the ultimate, front forks. You can improve front fork damping by changing the oil in the forks out to Dexron ATF. If you want even more damping, use Ford type Mercon ATF. On the question of the rear shock, a reservoir type shock is easier to change the damping on. Watch the swing arm bushings carefully, some of them have disintegrated in short order. If it was my bike, when they go, I'd change to urethane bushes. If I was real fussy, I'd change to bronze oilite bushings. Oilite bushings really tighten up the handling. Depends on how fussy you are.
Old 08-26-2016, 04:04 PM   #33
chuck   chuck is offline
You just answered my swingarm dilemma,mine was bone dry when I took it apart,I greased it all up, let's see how long it will last before I have to replace the bushings.I noticed some wear with only 700 miles on the bike.
Old 08-26-2016, 04:20 PM   #34
Ichrisbot   Ichrisbot is offline
My swingarm bushings were absolutely pulverized, fell apart like dust when I took the rear apart. They were bone dry as well, although I did do nothing but hard off roading with the bike up until that point.
Old 08-26-2016, 05:05 PM   #35
I've heard that before. The bushing is supposed to be vulcanized to the inner metal tube, and press fitted into the outer tube I think. What did you replace them with?
Old 08-26-2016, 05:38 PM   #36
AND, all may not be alright at the wheel end of the swing arm. So check to make sure that the axle is a good fit in the wheel adjuster. Some of them have been oversize.
Tire choices. The tire I would run at the rear is a Pirelli MT43, because here we have a lot of rocks and wet small stones in the creeks and water crossings in this part of upstate New York. And what we need is traction, or what English trials riders call "grip". A "security clamp/bolt" is a good idea, because you can run lower tire pressures. And you have to have your carburetion spot on for this kind of riding. What you don't want is wheel-spin. Remember, wheel spin digs a trench, and you have to climb out of that trench, sooner or later. You want to ride steadily through the water, making a nice Vee in the water. If the water is hub deep, you don't want to stop because when that cold water hits the front wheel bearings, the chill will encourage water to get into the bearings. The Vee in the water is to keep the wheel bearings dry. A trials type tire on the front also helps to keep you from slipping on the wet rocks. Stand up when crossing streams in order to lower the outfits center of gravity. If you have to ride very far on the road to get to where the fun is, you might try changing countershaft sprockets for the off-road part of the day. Buy a new chain (Unibear is a good one) and an extra (or two) master links with it. Buy enough chain so that you can get the longer piece for the on road sprocket out of one chain. I would change the bolts that hold the countershaft cover to allen screws, and carry the allen wrench with you. Quality American allen screws, please. I'm sure you will change the sprocket attaching bolts to allen screws as well, so you don't have to carry a ton of tools.
Old 08-27-2016, 01:57 AM   #37
hertz9753's Avatar
I don't know what to say about the picture. I think my Hawk was peeking into the shop when it was young and looking at the old Belsaw grinder and Foley belt sander.
Old 08-28-2016, 10:13 AM   #38
Hawkie-Talkie part 2
I mentioned in passing that the Hawk has a 21 inch front rim, and an 18 inch rear. These are probably the closest to perfect sizes around these days for off-road use, and works well on-road as well, with the right tires. You will find you have all kinds of tire choices for those wheels. The tire choices depend on where you ride. Where I live (on the northern slope of the Adirondaks), trials tires (with rim locks) work very well. Wet rocks, tree roots, wet ledge, and they work pretty good on the road. Better than knobbies on the road. Trick with trials tires is low tire pressure, which is why you need rim locks. How low? Depends on your weight. Four to eight pounds front, six to twelve pounds rear is a place to start. I always used to carry a spare front and rear tube with me, just in case. Three tire irons as well. So you probably need to install a burrito tube to carry them in. I always carried a long thin bicycle pump on the frame for emergency uses. You can take some of the plastic trash off the bike to balance the extra weight, if you want. It will pay dividends to spend the money for high quality, heavy duty natural rubber tubes, like Michelins, for example. Natural rubber is tougher and more tear resistant than synthetic rubber is. If you ride a lot on sand, like the Mojave Desert, you may want to switch to a 19 inch front rim for more flotation. But that is an expensive alteration for a entry-level priced motor-cycle. I must warn you that it is imperative to keep all of those spokes snug. I use the short spoke wrench, because it is harder to over tighten them with one. Mark where you start and tighten every third spoke all the way around, then go around again on the next spoke, then again for the last ones. It will take you three trips around the rims to get them all tight. If the spokes are tightend regularly, and you still break spokes, order a set of spokes from Buchannon's and replace them one at a time just like you tightened the spokes, except not as tight until you have got them all in there, then go around three times and get 'm snug. You probably won't have spoke breakage issues if you never let any get loose.
Old 09-02-2016, 02:01 AM   #39
hertz9753's Avatar
I was my shop yesterday and I noticed a KX clutch cable that I bought back in 2000 for my 1980 125. It was still in the plastic and OEM from Kawasaki. It was high up and behind an ED11 tire.
Old 09-02-2016, 03:59 AM   #40
pete   pete is offline
pete's Avatar
[QUOTE=Ariel Red Hunter
[/QUOTE]
just as a matter of interest the MT43 is a trials tread patten
tire that can be used on the road..
Dunlop 803 or Michlin trials light are to soft and melt with any heat
from the seal... and are all over the place in the corners..
i replaced the dunlop 803s on my trials bike as there were only around
1/4 worn I put them on my XR250... melted the rear tire in 15km on the road..
stay with the pirelli MT43 for road use... or a newish trials patten tire out
is the "MotoZ mountain hybrid" it's diffrents to other trials patten roadable tires
is it has a rounded profile un like the square profile of a normal trials tire...
But if yer want insane traction
& don't ride on the seal use the Dunlop 803 or Michlin trials light..
rubber compond & case constuction are for pure trials use...
even high speed offroad use on hard surfaces can over heat them..
So what I'm saying if yer after a trials patten tire... be careful what yer buy
theres trials patten tires & trials tires.. they a completely diffrent animals these days
not like the old days when a trials tire was a trials tire...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 09-02-2016, 08:35 AM   #41
Bruce's   Bruce's is offline
Holy crap Pete ,on this side of the world we certainly can't hunt or ride on a seal anymore .
Old 09-02-2016, 10:26 AM   #42
Yes as to the short life of modern trials tires, except for the Pirelli MT43. I'm sure the MT43 can not compete mano a mano with the modern super soft trials tires, but works great on dual sports, for my style of riding. Others, particularly in the southwest parts of the United States, may well prefer knobbies. But knobbies don't work that well here, in the northeast. They don't perform all that well at the lower speeds we have to run over wet slippery rocks and tree roots. I've never been able to ride on a seal. They always swim away before I can get close enough to get on one.
Old 09-02-2016, 02:26 PM   #43
pcspecialist   pcspecialist is offline
Motoz Mountain Hybrid review from a guy that had "run an MT 43 for the last three years without switching to another brand of rear tire."
http://advrider.com/index.php?thread...eview.1043542/
Old 09-02-2016, 06:10 PM   #44
pete's Avatar
PMSL.......
seal = tar /bitamin.... or what ever you fella's over there call it...
But I think you buggers are just taking the piss....
"taking the piss = having a joke"
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 09-02-2016, 07:45 PM   #45
I took a piss in your direction Pete .
