07-11-2016, 02:39 AM | #31 |
I just got around to swapping the stock (rejetted main, shimmed needle) carb on my Hawk with a Mikuni and it is debatable if the slight improvement was worth the cost. I may have got the same results had I replaced the idle jet on the stock carb.
07-11-2016, 12:42 PM | #32 |
Am happy to learn you had success re-jetting a (I presume) Keihan carb. I used to road race (I was the wrench) a Honda fitted with those carbs. Finding jets for them was almost impossible. They were un-numbered, so I had to guage the openings. I hated to do that, as I never willingly stick anything stronger than a round toothpick in a jet to unplug it. Do I think a Mikuni VM is the ultimate carburetor? No, but can I get jets for it? Yes. And the jets are all numbered, making it easy (assuming you have a bunch of jets, and yes, I know the other meaning of "Assume") to go leaner or richer in steps that are repeatable.
07-11-2016, 04:20 PM | #34 |
It should. I did a rough measure with my calipers and the intake flange mounting bolts seamed the same.
This is what I ordered. Price floats around a little. Typical Amazon. https://www.amazon.com/MIKUNI-VM26-C...M26+%2830mm%29 Here are the jets I ordered. You'll need to pick the right ones for your elevation. Here's some info Weldangrind has provided for direct links to jets-r-us: http://api.viglink.com/api/click?for...-486_pilot.htm http://api.viglink.com/api/click?for...arge_round.htm The carb will come lean with a 100/20 setup. I went 115/30 at 3000 feet and it's a bit rich. I need to drop the pilot to a 25 I think.
07-11-2016, 04:38 PM | #35 | |
2016 TT250 2014 NSS300 FORZA 2014 UN200 BURGMAN |
07-11-2016, 05:07 PM | #36 | |
With your pipe, I fear this still may be lean at sea level but the clip and screw may help. I think the stock setup on the Keihin clone is a 108 if I heard correctly from rojo??? If I were you though, with pipe, at sea level, I'd order a 110 and a 112.5 main and a 22.5 and a 25 pilot and go from there. Jets are cheap.
07-11-2016, 05:16 PM | #37 | |
07-11-2016, 05:21 PM | #38 | |
http://www.jetsrus.com/FAQs/FAQ_miku...ihin_sizes.htm If I don't get my 3/4 to WOT hesitation/sputter issue solved, I'll be looking at swapping to a Mikuni. Set up lean at sea level might just be the ticket for my elevation. But might have to go a little richer if I swap out the exhaust too. Rojo
'15 RX3 (Rojo's) '15 RX3 (marzhere's) '16 TT250 |
07-11-2016, 05:31 PM | #39 |
Well crap. All this talk....and I ended up just ordering one now....and a new pod filter, just in case. The carb sticks out sideways compared to the other CG motors I've had (the intake flange looks reversed) so I got a bent K&N style pod filter that will point it back into the frame. Not cheap but looks like it would work well.
07-11-2016, 05:32 PM | #40 |
Almost forgot. While scanning ebay earlier today, avoiding work, ran across a similar carb to what is on the TT, a Keihin carb with an accelerator pump.
http://www.ebay.com/itm/231591352354...%3AMEBIDX%3AIT Any thoughts, pros, cons, to the accelerator pump? Rojo
07-11-2016, 05:42 PM | #41 |
Definitely start with the 20 first, I made the mistake of ordering 25, 30, and 35 just to cover all possibilities and I suspect the 20 that came with it would have been fine even though I am using a 25. I'm running a 115 for my main (I think, I could have the 117.5 in it). The 115 is maybe a tad too lean at my low elevation, but, fine for where I do much of my riding. No cat and modified my muffler some.
07-11-2016, 05:46 PM | #42 | |
With these small displacement motors, I've had no problems with the cable driven slides and throttle response. It's been the CV carbs that have given me the most headache of any..... Temperamental and need to be run regularly.
07-11-2016, 07:47 PM | #43 |
Mikuni? 115 and 20 seems to work ok. Throttle slide number is probably good for you. Be very careful to not change the float height.
07-11-2016, 07:53 PM | #44 | |
07-11-2016, 10:58 PM | #45 | |
