05-21-2016, 01:34 PM | #31 |
Intake valve not closing or ignition timing (though I don't see how it could get that out of time).
05-21-2016, 01:34 PM | #32 | |
2005 Kazuma Cheetah 200 (Swamp Thing) |
05-21-2016, 01:40 PM | #33 |
So getting 60 psi consistently so maybe the valves are not the problem. Going to run a wire cleaner through the jets and see if that does anything.
05-21-2016, 03:01 PM | #35 | |
This is turning into a winter project, I just wanted to ride a little ha-ha.
05-21-2016, 03:49 PM | #36 |
Okay, been reading and retested with multiple kicks and got it up to 92 psi. Still not where it needs to be but maybe enough for the valve adjustment to help. Just want to get it running for the summer then can redo the motor over the winter.
It was running so hopefully I can get it back.
05-21-2016, 04:13 PM | #37 |
It was running, on starter fluid, this is totally a fuel issue. Pulled the carb, blew out the jets, all sounded clear, next going to eliminate the gas tank and line, I'll rig something up. This is something stupid!
05-21-2016, 05:11 PM | #38 |
Are you using original carburetor it might need to be rebuilt or replaced
2016 TT250 2014 NSS300 FORZA 2014 UN200 BURGMAN |
05-21-2016, 05:13 PM | #39 |
open valve does just what you are saying ... it will run on starting fluid because 1. it does not need vacuum to get it out of the carb 2. it needs less compression to fire starting fluid
05-21-2016, 05:42 PM | #40 | |
So I feel better, but funny thing is I was thinking this the issue from the start as I had the same problem with my mower.
05-21-2016, 05:45 PM | #41 |
From what I can find looks like .008 on exhaust and .005 on intake, that sound about right?
05-21-2016, 05:58 PM | #42 |
the "T" will be on top at the right place ant the wrong place, it could be 180 off still ... hold your finger over the spark plug hole till you feel air pushing, the bring the "T" to the top
05-21-2016, 06:22 PM | #43 |
Yup, no discernable gap.
05-21-2016, 06:37 PM | #44 |
Okay, set gap, kicked it over a few times with plug out, rechecked gap. I'll button her up later and see if there is any change in prognosis.
05-22-2016, 10:06 AM | #45 |
Got the motor dropped and the valves adjusted yesterday afternoon, putting it all back together today and see if she will start.
