Old 12-04-2010, 03:54 PM   #31
So you scooped up the bike?
Old 12-04-2010, 04:00 PM   #32
Very much so. Check out the new thread I started!
Old 12-04-2010, 05:16 PM   #33
Originally Posted by FastDoc
Wow good news!
Thanks for the information and research gentlemen!
I have started a new picture thread. I look forward to doing this project with you all.
Welcome back to The Collective, Billcutus of Zong; we missed you! Once again, you have made a major score; congratulations!
Old 12-04-2010, 08:31 PM   #34
katoranger's Avatar
I believe that yamaha had the TTR230.
Old 12-04-2010, 08:42 PM   #35
Yamaha currently manufactures the TT-R230, Allen.
http://www.yamaha-motor.com/sport/pr...4/0/specs.aspx
However, the Yamaha has a 223cc engine, the same engine formerly employed by the TT-R225, and XT-255 motorcycles. Zongshen has added 7cc more displacement to their ZS172FMM engine.
Old 12-04-2010, 08:46 PM   #36
katoranger's Avatar
I wonder if they get the extra 7cc from that modified head with the exhaust flipped.
Old 12-04-2010, 08:48 PM   #37
Here are the figures for the Zongshen engine: 72.5mm Bore x 55.7mm Stroke
Here are the figures for the Yamaha engine: 70.0mm Bore x 58.0mm Stroke
Therefore, the connecting rod, cylinder, piston, piston rings, cylinder head, et cetera, are different between these two motorcycles.
Old 12-04-2010, 08:51 PM   #38
Hey Spud, what do you make of the weak spark? Does that rule out the CDI? Coil?
Old 12-04-2010, 08:59 PM   #39
I don't know, Bill. :? It could be either of those parts, or the stator as well. :roll: In any event, it won't cost you much to fix it. Break out the multimeter, and get to work; we want to see this bike running!
Old 12-04-2010, 09:01 PM   #40
I don't see how the stator could cause it :?: . Wouldn't that just keep the battery from charging? I should mention the bike is electric start only, no kickstarter.
Old 12-04-2010, 09:12 PM   #41
If you don't mind, Bill, let's terminate this thread, and keep the questions to the other thread; otherwise, I'll get too confused!
Old 12-04-2010, 09:12 PM   #42
I would say don't presume that the plug is ok, just because it's new. Maybe it's a clone, or maybe it was dropped. New plugs are cheap enough that you could rule that out with a genuine NGK.
