09-15-2019, 07:13 PM | #31 |
My big butt likes the 2.6x range as well, and it works good for a mix of flat land and moderate hills.
As far as the 520 and the 13t front sprocket. Results may vary. Mine fit just fine.
09-15-2019, 08:38 PM | #32 |
I have a stock HAWK meaning I only have the air box and carburetor tuning modifications. I have a 520 chain and had the 13t 35t ( 2.6X ratio) installed for a short while and I will say a great ratio no doubt. The first time I shifted from 1st to 2nd I thought wow you can wind out 1st gear and 2nd is sweet on rpm too, but I live in mountain country and the flatland quickly becomes hilly and then mountainous so power up a grade is important. What I found navigating up some fair sized hills compared to other ratios was a greater loss in power and speed with the 13t and I weigh 180 lbs. I have an 11t installed now (courtesy of Dan's research) which figures 3.1X and I can run almost the same WOT top speed of 60-62 mph AND it maintains greater speed up the hills than the 13t apparently better utilizing the stock engine band power output.
09-15-2019, 09:24 PM | #33 |
I think its the Uni-Bear chain. Mine was ever so slightly rubbing the cover with the 12 tooth on it, and it definitely wasn't going on with the 13 tooth.
09-16-2019, 11:41 AM | #34 |
13t can also be solved with the 520 13t reverse keeper installation which requires grinding the sprocket cover. I found it runs great that way and I install all my sprockets in reverse keeper to get good clearance from the case. 13t is too good of a ratio to let the issues stop you in my opinion.
09-16-2019, 01:22 PM | #35 |
on stock bike with stock sprockets, my hawk would top out at 60 whether alone or 2 up. now it tops out at about 75 with myself and 65 2 up, at a much nicer rpm. I weigh 165 lbs. I currently have it at 17/44,
09-16-2019, 09:45 PM | #36 | |
09-17-2019, 07:19 PM | #37 |
if anyone can help please. tried to pull out the screw to see top dead center and i guess it was too tight idk it stripped out. any ideas to get it off? reason im doing it is because there is a quite a bit of ticking coming from valves. how much tick is too much?
09-17-2019, 11:08 PM | #38 | |
09-18-2019, 02:38 PM | #39 |
Makes sense. Two ways to get strength. The cheap way, which is more of lower grade material. The more expensive way, less of a higher grade material.
09-19-2019, 09:15 PM | #41 |
You can add another Bashan to the Hawk class at max 64 mph. 17/46 is the gearing. Rider is 200lbs with 30 pounds of TKC80 100/120 knobby wide tires.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
