09-14-2012, 01:16 AM | #31 |
I have the Roketa DB-06, I can get the front tire for the same price here's the link.
http://www.roketa.com/product/parts_...SSEMBLY%285%29 i'll see about truing it tomorrow, if i fail, i'll probably buy the new wheel assembly to get it over and done with. or i'll just buy the new assembly, and true my current wheel during the winter, and buy a different tire type to throw on it. I'll see about the truing tomorrow.
2021 Boom Vader Gen 2 BD125-10 Current 2011 DRZ400S Current 2006 LIFANIZED ROKETA DB-06 200cc Sold 2008 Ninja 250R Sold 1984 Honda aero 125 Sold 1980 Honda CM400T Sold |
09-14-2012, 01:24 AM | #32 | |
If you buy a front wheel assembly and plan to use it as a spare wheel, you will also need to purchase a front brake rotor, part #59. You will also need to buy brake rotor bolts; however, I bought bolts at the local hardware store to secure my Zongshen brake rotor. Spud
09-18-2012, 01:57 PM | #33 | ||
How long did it take for you to get your assembly, spud? it's getting colder and colder, want to have my bike good to go! though i have been preoccupied with other things so patience isn't to much of an issue. thanks!
09-18-2012, 04:49 PM | #34 | |||
09-20-2012, 06:50 PM | #35 |
ahhg, after waiting 4 days, i found an email to contact them. I asked them if they had any info on my order. got an email back saing
"I DONT HAVE THAT RIM" So idk what to do at the moment, i wonder if another wheel will fit. i sent them an email asking if they know of another rim that will fit my bike. ahhg. I think my front axle is fatter than most. Im going to try and true it my self tomorrow, also i'll try and call this one guy that said he could do it this week, a week ago.
09-20-2012, 11:33 PM | #36 |
That's too bad, Gamma. :roll: When truing a wheel, it's important to make small adjustments. Don't try to correct the problem all at once. Many, small adjustments will true the wheel much faster, and more accurately, than trying to make large adjustments.
09-21-2012, 02:30 PM | #37 |
alright, the left and right wobble seems to be good. It seems to be a bit off up and down though, the zip ties will be touching the middle of the rim at most points, then at some spots, the zip ties touch a lower spot on the rim, closer to the spokes. causing what looks like a slight bounce in the rim, Any idea how to fix this??
Not going to do it, but i'm guessing tightening the section in witch the zip ties are touching the lower part of the rim, pulling the rim closer, thus fixing the difference.
09-21-2012, 02:44 PM | #38 |
You need to true for radial symmetry before you true for lateral symmetry. The same principles apply. If you tighten a spoke if will draw the rim nearer to the hub. If you loosen a spoke, it will push the rim farther from the hub. You want to loosen the spokes on the low side of the wheel first, before you tighten the spokes on the opposite, high side of the wheel. Remember, small adjustments are best. Loosen or tighten the spoke nipples only 1/2 turn of so, then check your work. If you are making progress, make another small adjustment, and check again. Repeat this process until the wheel is true.
09-21-2012, 02:52 PM | #39 | |
09-21-2012, 03:16 PM | #40 | ||
09-21-2012, 03:30 PM | #41 | |||
I took it on a short ride, it feels right back to 100% again, i'm pretty happy with it, it was only slightly out of radial roundness. Though, i will check it again before i ride it again. Looking at the wheel spinning, while riding, the wheel looks perfectly trued laterally, and the bouncing at low speeds that i had before, is gone. And the rotor no longer rubs against the brake pads. That zip tie method, WA suggested worked great. Thanks for all the explaining you did SpudRider, i really appreciate it, and it seems to have paid off. a shame that not all my parts are available through roketa.com though, oh well.
09-21-2012, 04:36 PM | #42 |
Good work!
You are well on your way to your online motorcycle technician certificate!
Happy to serve. |
09-22-2012, 12:06 AM | #43 |
You're welcome, Gamma.
09-22-2012, 01:45 AM | #44 |
TheGammaGhost, your patience and persistence is admirable. Thanks for following up.
09-22-2012, 09:29 AM | #45 |
I am impressed. Truing wheels is a task that many won't attempt.
