Old 07-23-2015, 12:46 PM   #3946
3banger   3banger is offline
3banger's Avatar
Damn you auto correct
Hand Guards!
My hand grass is personal problem I would rather not discuss...
Old 07-23-2015, 12:58 PM   #3947
Hand Guards!
Old 07-23-2015, 02:06 PM   #3948
rjmorel   rjmorel is offline
rjmorel's Avatar
Hand Guards!
)))))))))))) rj
Live Zong, and Prosper
Old 07-24-2015, 02:13 PM   #3949
There is another center stand being produced for the Zongshen RX3. You can read about it at the following thread.
http://cyclone-rx3.com/forum/viewtopic.php?f=17&t=70
Old 07-24-2015, 04:46 PM   #3950
DanKearney   DanKearney is offline
Great idea. Nice execution. Now, to throw my non-engineering opinion into the mix, any chance you can add a leverage bar to it to make lofting the loaded bike up easier.
Like this:
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 07-24-2015, 04:57 PM   #3951
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
I'm looking into the idea. However, because I've had to move the center stand's pivot point rearward to get the bike to balance in the proper place, a leverage arm would interfere with the normal operation of the kickstand.
What I am currently doing is messing with the leg length of the center stand to find that happy medium walk-over point. It might mean that 2 inches of vertical rear tire lift could reduce to only 3/4", but that's my target minimum. (A sheet of wood) As that would still allow for free tire movement even if you had knobbies.
However, as opposed to the stock center stand offering, mine has very large footpads that you can step on while rocking the bike back.
Old 07-25-2015, 01:36 AM   #3952
Perhaps a stud welded onto the footpad would be a benefit.
Old 07-25-2015, 02:06 AM   #3953
Eco Mouse's Avatar
If you notice in the pic, the center stand nests just under the kick stand. A bolt, or an arm of any kind will interfere with the kick stand swinging down. Right now as designed, it just clears it.
But the center stand works just fine without an extra appendage. I may dip the feet into truck bed liner to help with smooth shop floors. As mine is epoxy coated and I'd just like to not be scratching the floor every time I use the center stand. But the rubberized coating will actually help give you a bit of traction in your garage.
Old 07-25-2015, 09:32 AM   #3954
CSCDude   CSCDude is offline
CSCDude's Avatar
Spud, where are you?
Joe
www.ExhaustNotes.us
Old 07-25-2015, 02:26 PM   #3955
Welcome to the Gem State.
I didn't have an opportunity to connect with you, but I'm glad you hooked up with AZRider, and will be meeting others near Boise. Ride safely.
Old 07-25-2015, 04:28 PM   #3956
katflap   katflap is offline
katflap's Avatar
Fitting a relay for my heated grips prompted me to finally fit the rest of my daytime running lights as i now had an easy source of ignition switch controlled power.
These are just dirt cheap LED lights and switch from ebay. They seem quite effective, all for under £10 ($15).
The extra LED brake light and indicators on the topbox i had done previously. This LED strip was quite cheap too.
Name:  Aux Lights 1.jpg
Name:  Aux Lights 2.jpg
Name:  Aux Lights 3.jpg
Old 07-25-2015, 04:30 PM   #3957
katflap's Avatar
also i have fitted a water proof micro switch to my side stand.
I have it wired to the horn.
So if i turn on the ignition with the side stand down i get a loud reminder..
This suites me as i always kick the stand up before switching on. Though i always do this my memory ain't what it used to be.
I have wired in a hidden switch so i can disable it if i choose.
Name:  Side Stand Micro Switch.jpg
Old 07-25-2015, 05:37 PM   #3958
Adjuster's Avatar
I really like your switch stand reminder.
Old 07-26-2015, 12:02 AM   #3959
AZRider   AZRider is offline
Disappointed that we didn't get to see you today Spud, we had a good ride and are headed to Hells Canyon tomorrow. It's a great and diverse group and they actually play well together. Just goes to show that the common bond of the Zong over comes any negative.
George
2016 CanAm Spyder F3-L
Old 07-26-2015, 12:12 AM   #3960
As always, you did a very nice job, Kat. Thanks for sharing your modifications with us.
Indeed, I also like your microswitch very much.
