Old 07-20-2015, 12:05 PM   #3931
Originally Posted by woodlandsprite View Post
Thanks Weld
So....what does it mean to lug the engine? Is it basically making sure the engine isn't in too high of a gear for the speed at which I am trying to travel? I have very little experience with manual transmission vehicles. I rarely drive our truck, and then only on dirt roads...
And winding it out is when it's got its RPMs too high - so in too low a gear for the speed at which I'm traveling (uh...how does this work with engine braking??)
Is there a way to find out what the optimal RPMs is for a given engine? This is clearly another skill i'm going to have to pick up and learn...
Spud's response was ideal.
Since you brought up engine braking, I'll throw out a new challenge for you. New riders will often simply pull in the clutch, downshift and then release the clutch, which can result in aggressive braking. When you pull the clutch in to downshift, give the throttle a quick rev (not too much) as you kick the shifter down, and then gently release the clutch (vs. dumping it).
After some practice, you should feel very little engine braking, but rather a smooth transition from gear to gear. It makes for a more pleasant ride, and it's easier on your bike. Be patient with yourself as you experiment with this technique; it takes time.
Old 07-20-2015, 12:39 PM   #3932
detours   detours is offline
detours's Avatar
Originally Posted by rjmorel View Post
Detours, are you posting ride reports anywhere? How's you wife like the TU250x. I think they would be a fun ,cool little bike to travel on, rj
Hey RJ, here's a ride report for you
http://www.rx3forums.com/forums/show...d-Rollins-Pass
Red 5 standing by!
2014 Ural Patrol
Old 07-20-2015, 12:56 PM   #3933
detours's Avatar
Our RX3 bikes have optimal power and fuel mileage when the engine is turning about 5,000-7000 rpms.
You are correct regarding lugging, and winding out the engine. You can hear the engine winding up to higher rpms. This sound is your signal to shift; don't look at the tachometer. Listen to the engine. When the rpms reach about 5,000-6,000 rpms, it is time to shift from a lower gear.
I find with the 14 tooth sprocket, my RX3 likes to cruise at 6000-7000 RPM. It reaches peak power somewhere between 8000 and 9000. I generally shift above 6000 RPM ... a little higher on hills and maybe a little lower on the flats. Like Spud says, once you learn how that sounds, you'll shift by sound and by how the power feels, not by watching the tachometer.
Red 5 standing by!
2014 Ural Patrol
Old 07-20-2015, 01:22 PM   #3934
If you have time, please do post your ride report here, also.
http://www.chinariders.net/forumdisplay.php?f=113
Old 07-20-2015, 01:56 PM   #3935
I'm sorry to hear of you minor spill at the end of the ride, but I'm glad to know you and the bike escaped with only minor damage.
Old 07-20-2015, 02:10 PM   #3936
DanKearney   DanKearney is offline
Where did you see 30.2 ft-lbs of torque? Their specs page lists 16.5 ft-lbs.
Here: http://www.cscmotorcycles.com/product-p/zrx3-b.htm
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 07-20-2015, 02:17 PM   #3937
rjmorel   rjmorel is offline
rjmorel's Avatar
Thanks for the great pics and report Detours. I found a lot of bolts loosen up after my first ride in Hell's Canyon so when I went over them after the ride I replaced lost ones and lock-tited them . Part of the doings of adventure riding. rj
Live Zong, and Prosper
Old 07-20-2015, 02:48 PM   #3938
3banger   3banger is offline
3banger's Avatar
Ya that HP number is clearly a typo. 30.2 ftlbs at 7000 rpm. Would be 40 hp!
Old 07-22-2015, 12:34 AM   #3939
AZRider   AZRider is offline
Thumbs Up Off and running
Got back yesterday from a 25 day ride on my Spyder to Alaska with a group of 10 Spyder Ryders. 8,622 mile roundtrip and averaged 345 miles/day.
Spent today getting the RX-3 ready to go to Idaho and meet up with the CSC group for a few days of riding.
Ain't retirement wonderful!
George
2016 CanAm Spyder F3-L
Old 07-22-2015, 08:29 PM   #3940
woodlandsprite's Avatar
I'm jealous I've been toiling away at work dreaming about more riding practice...
Don't forget to take lots of photos and have a wonderful time!
Old 07-22-2015, 10:13 PM   #3941
Thanks Sprite. I've come to the conclusion that a bucket list is pointless, I need a 45 gallon drum!
George
Old 07-22-2015, 10:17 PM   #3942
That's going on the fridge!
Old 07-23-2015, 12:25 AM   #3943
cimarronEric   cimarronEric is offline
Originally Posted by 3banger View Post
Any Imogene photos? Did you make it to the top? I'll be riding Imogene pre Imogene running race. My girlfriend is running and I plan to be assiting up top. I rode her XT250 up their last year no problem. I need to get down that way and pre ride it!
Eric, maybe we can get a CO RX3 group 13t sprocket group order together.
I made it from the Telluride side today.
We just won't talk about going over the handlebars on the way down...
When are you pre-riding? I'd love to try to join you.
Noooob
CSC RX-3 Cyclone
Old 07-23-2015, 08:50 AM   #3944
3banger's Avatar
Sound like you are certainly making an adventure out of it!
I plan to be down there Sat. Hopefully I can make do with the stock rubber. I will have hand grass in place.
Old 07-23-2015, 12:36 PM   #3945
rjmorel's Avatar
What's "hand grass in place" mean ??????? I'm kinda slow. rj
