Old 05-28-2015, 05:46 AM   #3616
I installed a SpeedoDRD from 12 O'Clock Labs to correct the highly 'optimistic' reading from the speedometer of my Zongshen RX3. I like this speedometer corrector very much, and I am pleased I purchased it. If you like, you can read my installation thread at the following link.
http://www.chinariders.net/showthread.php?t=14756
Old 05-28-2015, 11:54 PM   #3617
Miqueas   Miqueas is offline
Hi all, is there any guide for installing the big box? The one with the seat.
Old 05-29-2015, 12:36 AM   #3618
Are you asking about the Garage Pro Travel Trunk?
If so, follow the link below.
http://www.chinariders.net/showthread.php?t=14712
Old 05-29-2015, 12:49 AM   #3619
The stock one. I asked to be taken out all the extras (including the rear plate), but now I want to put one box.
Old 05-29-2015, 01:06 AM   #3620
You can find that information at the following link.
http://californiascooterco.com/blog/?p=15621
Old 05-30-2015, 12:33 PM   #3621
Thanks. I just installed the top box. And I get some crissement. Is there anything I can do? Or is it like this in all the bikes?
Old 05-30-2015, 02:25 PM   #3622
Adjuster's Avatar
LOL I had to look it up and translate. Crissement = Screeching
Old 05-31-2015, 12:56 AM   #3623
If you installed the rubber grommets and washers, you should not hear any noise from the trunk.
Old 05-31-2015, 04:15 AM   #3624
JTHSPACE   JTHSPACE is offline
JTHSPACE's Avatar
In the past, I have had "rumbling" from the box as it is not a tight fit onto the rubber buffers on the holding rack. My solution was to stick hard foam strips under the box so that you have to firmly "force" the box onto the locking mechanism. I started with two pieces either side of the box 5mm thick, tried thicker, but it would not compress enough. The 5mm (quarter inch approx) rubber foam worked.
I stuck it on the box and not the rack mount so that it wasn't visible when riding with the box off.
The foam I used was the hard to compress type. It was black high density, not the type of foam from a bath sponge or disk scrubber.
Hard to describe, but I hope you get the idea.
Jeff
Riding bikes for over 40 years
Honda C50 / SS50 / CB125 / CB250
Velocettes (various)
Piaggio's / Honda's / Yamaha's
Raptor . . . . the List Goes On . . . .
Old 05-31-2015, 08:15 AM   #3625
Jeff
Thanks for your input, Jeff. That is an excellent solution for the Garage Pro/J.C. Whitney travel trunks which attach to the luggage rack with a locking mechanism. However, I think Miqueas is having problems with the stock trunk of the RX3, which is bolted to the luggage rack of the RX3, and is not designed to be easily removed. This trunk is supplied with three rubber grommets, three extruded washers, and three bolts which secure it to the luggage rack. If the supplied equipment is used, the truck is firmly attached, and shouldn't make any noise.
Old 06-01-2015, 10:20 AM   #3626
jimjr21   jimjr21 is offline
I finally measured how much fuel it took to cover the fuel pump. Starting with a completely dry empty tank filled to cover pump while on center stand. It took just over 1 quart or little less than 1.5 liters to cover pump.
Now the extra fluid recommended by the factory can be for increased thermal capacity of more fluid, or complete immersion while fluid is sloshing around.
Either way there will be a lot of useable fuel after the gauge shows empty especially on smooth roads.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 06-01-2015, 11:13 AM   #3627
Thanks for measuring, and sharing that information, Jim. I have always thought the Zongshen engineers were being very cautious and overly conservative with the full gallon specification.
Old 06-01-2015, 08:13 PM   #3628
DanKearney   DanKearney is offline
My old XT225 sold over the past weekend, so I pulled the trigger on the RX-3 this afternoon.
They were out of my preferred color (white) but really talked up the blue (Orange is too KTM for me anyway. . .). They expect it'll ship out on Friday.
I had them throw in the 19" front wheel and center stand too.
Can't wait. . .
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 06-01-2015, 11:37 PM   #3629
rjmorel   rjmorel is offline
rjmorel's Avatar
Welcome and congrats on the new RX3 Dan. You'll enjoy the Cyclone as it is a great little bike. Be sure and check oil, coolant levels before riding. My coolant showed the normal 1/2 in the overflow tank but was way down in the radiator. Rode it that way for 300 miles before taking radiator cap off and checking. Checked it several times as it took a while to get coolant over into the second radiator and back around to fill it up to the cap neck. rj
Old 06-02-2015, 12:16 AM   #3630
Congrats Dan! I hope it serves you well.
