Old 05-01-2015, 02:03 PM   #3271
rjmorel   rjmorel is offline
rjmorel's Avatar
Thanks Spud for creating the new forum. That must take a lot of time? Did you have to run a drill in the handlebar ends before tapping them 1/2-13 or did you just run a tap in? Thanks, my Rx3 is suppose to be here today or Monday. rj
Old 05-01-2015, 02:09 PM   #3272
Quadz is the owner of these forums, and he created the new RX3 forum. All thanks should be directed to Quadz.
No, I did not need to drill the handlebar. I merely ran the tap for the 1/2"-13 thread into the existing holes.
Old 05-01-2015, 02:24 PM   #3273
Huck369   Huck369 is offline
Huck369's Avatar
It looks good, Huck. Please remind me. What handguards, and what bar risers did you install?
Tusk Risers...
And cheap Hand Guards off Ebay....knock offs of some of the Acerbis ones.... they came with spoilers too, but I haven't mounted them yet...
http://www.ebay.com/itm/Carbon-7-8-D...d10e07&vxp=mtr
The link looks to be the same maker...but no spoilers with it....
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 05-01-2015, 02:26 PM   #3274
Thanks for the reminder. Good for you.
Old 05-01-2015, 02:33 PM   #3275
Originally Posted by katflap View Post
Just got a new toy for lifting my Rx3 off the deck. Will do the car as well.
Seems quite good though I was the only one impressed.
The wife wasn't as the delivery man left it propped against the door and she struggled to get in the house.
The cat wasn't arsed but liked the box it came in
I like it.
I used a similar, Husky brand jack, which I bought from Home Depot, to lift the RX3 when I changed the fork oil. If you remove the circular lifting pad from that jack, it reveals a hollow tube underneath.
After positioning my RX3 on a swingarm stand to lift the rear wheel and level the motorcycle, I removed the skid plate. The front bolt for the skid plate is screwed into a bracket. I placed the hollow tube of my Husky jack around that bracket, and used it as a solid support to jack up the front wheel. This is the same method I used to install the front wheel when I assembled the motorcycle out of the shipping crate.
Old 05-01-2015, 05:08 PM   #3276
katflap   katflap is offline
katflap's Avatar
Thanks for the tip Spud, I have a paddock stand for rear so should be able to do as you described
Old 05-01-2015, 11:47 PM   #3277
pete   pete is offline
pete's Avatar
Originally Posted by detours View Post
Much better! The Kenda looks like a good match for the Shinko rear!
With all the offroad riding you do, were you intending to retire your Zongshen 200 or use the RX3 for more road use
Have you noticed the two contact rings around the front disc...
is it not true / flat ?
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 05-02-2015, 01:11 AM   #3278
That's a cool jack. I considered making an adapter for my car jack, so I can lift my bikes in a similar fashion.
Old 05-02-2015, 02:49 AM   #3279
Thanks for noticing, and making me aware of this.
The brake rotor is definitely true. The front brake performs smoothly, and very well. I believe the camera is magnifying two faint rings which are disappearing as the brake pads wear in. However, I will definitely keep inspecting this rotor.
Old 05-02-2015, 11:55 AM   #3280
Here are a few photographs of the new tires I mounted on my Zongshen RX3.
I installed a Shinko 244 tire on the rear wheel; it was size 5.10-17. I mounted a Kenda K270 tire on the front wheel; it was size 3.50-18. Both tires are working well for me.
I bought both tires from Rocky Mountain ATV/MC.
https://www.rockymountainatvmc.com/p...ual-Sport-Tire
Old 05-02-2015, 01:56 PM   #3281
katflap's Avatar
Great photos as always spud , I can imagine the more aggressive tyres are a lot better for off road riding. Do they handle ok on the street ?
I recently checked my wheel spokes and noticed a few on the front wheel were sounding a bit loose.
I went through the spokes checking every forth spoke in rotation, tightening the loose ones to what felt like the same torque as the tighter ones.
The spokes that were loose now have a low to medium pitched ping compared with the tighter ones.
Do you think that this is good enough or should they all have a similar pitch.
I don't want to end up with an egg for a wheel so reluctant to tighten any further without advice
Old 05-02-2015, 02:11 PM   #3282
katflap's Avatar
My Latest Bodge
I wanted to tackle the inaccurate speedo problem but am too tight to pay for a speedo healer.
So I fitted a bicycle speedo for £11.50 ($17.40)
To my amazement it works and is accurate ( tested against GPS)
this one is waterproof and auto switches on when moving and off when stopped
Old 05-02-2015, 03:21 PM   #3283
Jaume   Jaume is offline
First Km in my RX3!
Hi everybody, a few pics from Lago Caburgua with my ZS RX3.
50 Km away form my place, Pucón, Region de La Araucanía, Chile.
Old 05-02-2015, 03:45 PM   #3284
Mudflap   Mudflap is offline
Bicycle speedos are great, I have them on all my bikes. Avoid this model though because it goes crazy at anything over 71 mph.
Old 05-02-2015, 04:43 PM   #3285
G19Tony   G19Tony is offline
G19Tony's Avatar
I may have killed my battery
I put a pigtail on the battery, like I do with all my bikes. It's been on a BatteryMinder charger/conditioner for a few days. I finished up changing the oil and tried to start the bike. It wouldn't even run the fuel pump. I removed the battery, and it was bubbling out from the left side. It was accepting a charge, but the bubbling is disconcerting. I ordered a WPS battery for the bike. I have one on the Grom, and it works a treat!
490-2517 is the replacement for the OEM battery.
http://www.wps-inc.com/catalogs/stre...PAGEGO=Page%23
Honda CB300R ABS
