Old 04-22-2015, 04:49 PM   #3046
oldqwerty   oldqwerty is offline
Anyone know what kind of bulb is stock?
"Thou shall not Zong" is not a commandment.
Old 04-22-2015, 06:08 PM   #3047
G19Tony   G19Tony is offline
G19Tony's Avatar
I spoke to Steve earlier. He said it was an H4. I went out and bought a PIAA H4 that I will attempt to install this afternoon.
Honda CB300R ABS
Old 04-22-2015, 06:27 PM   #3048
Miqueas   Miqueas is offline
Originally Posted by jimjr21 View Post
I would look for exhaust leak.
Here are reasons why.
Immediate wind with heat. Radiators take a while to heat up. Instant heat leads to exhaust.
Right side has three possible locations that would have an easy leak.
1) header to muffler joint. There is a fiber material clamping and sealing the two steel pieces. Easy to damage (or be missing)
2) O2 sensor. Loose, missing, cracked weld
3) Header to head. Loose clamp or damaged or missing gasket. Outlet is faced to right side and wind speed would blow to right side.
Having ridden in 40-70F temps so far 1 and 2 up there is no noticeable heat on right leg for either of us. Wearing jeans or work pants.
Good luck in finding the source of heat.
Someone can help find this thing? I have not know much about motors and motorcycles.
Problem: right radiator is venting more and heater than the left.
This is my video
Old 04-22-2015, 06:45 PM   #3049
Veteran   Veteran is offline
Veteran's Avatar
Heat
This is my video
I have to ask this; are you wearing pants or shorts when you ride? (No one laugh please) , if you're wearing shorts, you'd notice the heat from that side more than you would if you're wearing pants. Like someones said earlier; if it's an immediate problem after starting, I'd suspect an exhaust leak. If it's after the motor's warm, then perhaps radiator fan. Those should be the only two sources of heat unless you've got an internal motor problem which would manifest itself by metalic noises and discoloration of the engine case or cyl.
Old 04-22-2015, 06:53 PM   #3050
jimjr21   jimjr21 is offline
Initial dyno test.
Inertial type at rear wheel.
16.60hp @ 8230 rpm
12.47ft/lb torque @ 5950 rpm
I will try and get some graphs loaded.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 04-22-2015, 07:07 PM   #3051
Adjuster's Avatar
Just looking at that video my first thought is the direction of the fan is going to throw heat either left or right.
Old 04-22-2015, 07:52 PM   #3052
fishman10's Avatar
horsepower
wow! those hp. numbers are alot less than advertised,,i think,if my memory of the specs. is correct!?? i could be wrong tho
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 04-22-2015, 08:44 PM   #3053
Excellent! H4 is good. I have several H4 upgrades from previous experiences. I've yet to hear any complaints about poor headlight performance, but I can't tolerate ineffective lighting and will definitely come up with a plethora of solutions. 300 watts is a lot to play with, especially since the Cyclone is all LED, which draws almost nothing.
Is the stock 35/35 an HID by chance? Pictures look like a projector lamp. Either would be a blessing. Both would be AWESOME.
Old 04-22-2015, 09:05 PM   #3054
Initial dyno test.
16.60hp @ 8230 rpm
To me, that's a good number at the wheel. I bet the factory specs are at the crank.
To put that in perspective, CG200 motors are rated for around 17hp at the crank; much lower at the wheel.
Old 04-22-2015, 09:48 PM   #3055
G19Tony's Avatar
Not an HID. Just a really dim light. I bought my PIAA at Cycle Gear, where they had an LED conversion kit. I didn't hold much hope of that working. I will wait and get a ZS LED light at some point.
Honda CB300R ABS
Old 04-22-2015, 10:47 PM   #3056
rjmorel   rjmorel is offline
rjmorel's Avatar
This is my video
Miqueas, Very good video. The only thing I thought of is seeing your overflow bottle seems to have a lot of coolant in it. Maybe it was over filled from the factory and it's burping out the excess now? I couldn't see any marks where it's suppose to be filled to so maybe someone else can check theirs and see where it's suppose to be???? rj
Old 04-22-2015, 11:36 PM   #3057
What is a ZS LED?
I'll wire up a relay and run one of the H4 60/55 bulbs I already have. That will keep it legal.
If more light is needed I have 7-inch round headlight housings that will take Hella ECE composites and H4s on a light bar. Not legal on cars, but legal on motorcycles. Maybe a bit heavy, but they give awesome light.
Old 04-23-2015, 12:45 AM   #3058
detours   detours is offline
detours's Avatar
This is my video
Miqueas, is the temperature normal on the dash? This is probably a long shot, but I wonder if coolant isn't flowing correctly from right to left ... air in the lines could potentially block the flow. You could try to 'burp' the coolant lines following the procedure at the end of this tutorial.
Also, do you have a warranty on your bike? Maybe the shop would look at it for you.
Red 5 standing by!
2014 Ural Patrol
Old 04-23-2015, 01:09 AM   #3059
G19Tony's Avatar
What is a ZS LED?
Zongshen. I work in aviation. We abbreviate everything.
Honda CB300R ABS
Old 04-23-2015, 01:10 AM   #3060
Perhaps CSC specified an H4 bulb, but the stock headlight bulb in the Zongshen RX3 is an HS1 bulb. HS1 bulbs are rated at 35W/35 for a standard bulb. Since the headlight output of the RX3 is fairly poor, I assume my RX3 has the 35W/35 HS1 bulb.
The H4 and HS1 bulbs have the same connector configuration. However, one of the connectors is a different thickness. Therefore, you can substitute an H4 bulb for an HS1 bulb, but not the other way around.
http://en.wikipedia.org/wiki/User:KDS4444/HS1_bulb
I plan to install an H4 bulb in my RX3 headlight, since the H4 bulbs have more power, and the RX3 alternator generates enough electricity to support the brighter H4 bulb.
