04-10-2011, 12:07 PM | #16 |
I fixed it for you Brian. If you past the link without the img tag, it will format properly.
Thanks for the pics. The new tires look great. 8)
04-10-2011, 04:54 PM | #17 | ||
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
04-12-2011, 10:30 PM | #18 | |
Do you guys think it looks ok? I can't wait to get the second hub so that I can try it out and make any adjustments needed. Plus, I use that atv for my around the yard work stuff and miss it as it has been up on the jack stands for a while now. I also made a couple more purchases for it. I'll start a new thread for it once the parts arrive. It has something to do with EFI and a turbo. Should be a fun project and I'm sure people will ask why. It's not that I'm trying to make it as fast as my Honda trx400ex or anything, but to enjoy the technical challenge of getting it all to work. Won't end up running a lot of psi, but just enough to give her a little kick. Excited... |
04-13-2011, 12:16 AM | #19 |
I think it looks good, Brian. 8)
I've toyed with the idea of experimenting with a turbo, but I'm a little concerned about heat. The vids of turbos on Briggs and Stratton engines on youtube are hilarious!
04-13-2011, 01:45 AM | #20 |
could you do a simple list of what components you bought and where you bought them from ?
like a shopping list of sorts, so when some one like myself considers doing this upgrade they know exactly where to find the parts and most importantly the correct parts.. also that thing between the hub and the rotor is that just a wheel spacer to push the hub out ?
