Old 09-23-2006, 12:08 AM   #16
gyjoe   gyjoe is offline
The part number for the 25x47x7 grease seal at bikebandit.com is 5086739.
2006 Lifan LF200GY-5
Old 10-24-2006, 10:34 AM   #17
mule3010   mule3010 is offline
When checking spoke tension and adjusting be careful not to over tighten or tighten out of sequence.
Joe
Old 10-26-2006, 11:19 AM   #18
I mentioned this in another post but be sure to route and properly clamp the spark plug wire. Mine worked loose from the clamp on the cooling fins on the back of the engine and got badly burned on the pipe. It melted the insulator and the protective plastic heat sheild in a relatively short period. (10-15 min.)
Joe
<li>2007 Roketa&nbsp;RSX-E 200<br />03 Kawasaki mule 3010 620cc&nbsp;4x4 utv<br />02 Polaris Trailblazer 250cc 2 stroker<br />06 Roketa RTU-90 ATV<br />06 Roketa Bermuda 150cc Scooter<br />05 3500 Dodge/Cummins&
Old 10-30-2006, 12:54 PM   #19
BCrider   BCrider is offline
Send a message via MSN to BCrider
The rear oil seal needs to be changed from the 27mm id to the 25mm id for sure. Where does the electric block(resister) bolt to??In the headlamp area. Also I am short a brake caliper bolt for the front any clue who would stock them ?? The choke cable looks to be to short anyone hae that problem?? Haven't started it up yet anything more that I need to look for?? Thanks in advance
Old 10-30-2006, 04:44 PM   #20
NewEnglandTrails   NewEnglandTrails is offline
Front Caliper bolt
BCrider, Welcome to China Riders!
The only question I can answer is about the front caliper bolt.
Before I joined this sight I found out the hard way about loctiting bolts.. When I lost a front caliper bolt, I just went to my local hardware shop and matched up the remaining bolt. Added lock washers, Loctited both bolts and its been fine since.
What brand 200-GY do you have anyway?
New England Trails!!!!
Old 10-31-2006, 08:07 AM   #21
LIfan
Old 10-31-2006, 09:59 AM   #22
Battery Box
My battery box (all steel construction) came apart yesterday. I finally realized something was wrong when I pulled into the gas station and saw my battery swinging in the wind with the cage still bolted around it. The two parts that bolts to the frame were still loc-tited and bolted to the frame. It appears they only tac-weld the cage and the tac-welds all broke after 500miles of riding. So, I had to go buy some JB weld and I still have it clamped and curing now. So, I'll let you know if it holds up or not. May want to check yours if you have this type.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 10-31-2006, 04:38 PM   #23
ImEazy   ImEazy is offline
Re: Battery Box
I have the plastic battery box. I wrapped two sets of zip ties around
the battery box and frame/seat rail just for this reason. I've since
found a web strap that I plan to install one day.
2000 MZ Baghira
Old 10-31-2006, 08:49 PM   #24
dlunt   dlunt is offline
Send a message via MSN to dlunt
The GY-5's battery box is metal and squished in between the engine, seat, tank and frame. I figure even if it works loose it isn't going anywhere.
Old 11-01-2006, 04:48 PM   #25
That's about where I want to finally install mine. Right now it's in the stock loctation (hanging out the back left side of the bike) 8O I guess the 10yr old that put it together also engineered this idea. Very few complaints otherwise.
Old 11-15-2006, 11:02 AM   #26
In reference to the swingarm grease fitting:
Also, I forgot to mention Dad and I removed the stock grease fitting for the swingarm axle and put in a new "standard" fitting. We then proceeded to pump and pump and pump and pump grease about 14-16 pumps until it was full. You guys may want to look into this. We couldn't get the grease gun to hook up to the stock fitting. It was too small and short. Ride quality seems to be a bit better since.
Jason
Old 01-22-2007, 09:55 AM   #27
You may want to reinforce the mounting holes on your side covers before installing them. I have pulled through on both the mounting holes and the holes are now the size of the mounting screw heads at both bottom locations. Not sure how to fix it at this point, but some fiberglass reinforcement on the backside could have maybe prevented this.
Old 02-07-2007, 08:03 AM   #28
If any of you guys decide to attach a case to your rear rack, keep an eye on the welds and stress points. Mine finally bit the dust after 3100miles. I know I was probably riding too hard with too much in the case most of the time, but that's just how it is Dad decided not to bother welding it again since it just broke in a different location this second time. He said he'll make a rack support for the new rack when I get it, that will bolt right to the frame under the center of the fender.
Jason
Old 02-16-2007, 07:41 PM   #29
amad   amad is offline
Originally Posted by gyjoe
Make sure your headlight fairing is insulated from vibration. Mine had good rubber bushings for the mounting screws on the sides, but the mounting strap on the underside of the fairing was only provided with a rubber washer for the outside and not where the strap attaches on the inside of the fairing, providing a direct route for vibration to the headlight bulb. Some have had problems with headlight life, and this could be one thing that is causing a problem. The rubber chain slider works at first, but mine will be worn through to the mounting screw within the first 500 miles. Start looking for a more wear-and friction resistant material (such as nylon) to replace it with.
What mounting strap? All I could figure out was that the headlight assembly had two bolts on the sides and one screw in the middle at the bottom front. And my bike does have a very annoying rattling vibration at certain rpms that could be coming from that.
Old 02-16-2007, 08:05 PM   #30
Also, there seems to be a lot of chatter coming from the top end of the motor. Has anyone had to adjust the valves when it was new? Also, I asked this in another thread, but has anyone had any oil leaks when it is new? I thought it looked like it was coming from around the exhaust header, but it may be coming from the valve cover. Has anyone had to tighten the valve cover?
