Old 02-17-2007, 09:30 AM   #16
ambassador   ambassador is offline
Just about any auto parts store carrys them, you may have to modify the connectors though...
Old 02-17-2007, 02:20 PM   #17
tzrider   tzrider is offline
Mine plugged right in, no problem. Just make sure it's a two pronged flasher.
Old 02-17-2007, 02:26 PM   #18
As to turn signals, I put one off a 600 Bandit on the front right because a guy I'd sold a Lifan to needed a lens and the one Diamo sent me was wrong. So, I gave him one off my bike, was what he needed. After riding it around with no turn signal lens for a while, I just installed the Bandit blinker from an old Bandit I parted out. Some Hondas will have a two filament bulb, just have to hook up the bright one. The other is a running light on the Honda. The Suzuki signal has one filament, though. I had to cut off a do dad on the post to fit it, but it was plastic, easy to do. It looks enough like the original light that you don't notice it unless you're lookin' for it.
Old 02-17-2007, 06:33 PM   #19
amad   amad is offline
I solved the beeping blinker problem. I found the rectangular beeper box and wrapped the heck out of it with electrical tape. It muffled it so much, you can't hear it when the bike is running. :P
Old 02-18-2007, 01:05 AM   #20
Jet_Tech   Jet_Tech is offline
Heres is another fix to your beeping winker problem...go but a tube of JB Weld and fill the hole and smooth it out...let it dry and reinstall...this way you dont have to counter balance the right side of the bike due to the massive tape ball on the left side.
Old 02-18-2007, 01:24 AM   #21
2 passes around with the elec. tape will do, not very waterproof though, may come outta the trail beeping..
Old 02-18-2007, 11:41 AM   #22
Yeah. I only wrapped it about 3 or 4 times with the tape. It still fits in the rubber mount.
2007 United Motors DTF-200,
2007 Ninja 650R
2007 Suzuki Boulevard M50
