03-03-2021, 08:37 PM | #16 | |
Fluids
I’m planing on doing things a little different this round. Draining the oil and do the valves first off. Gonna try and change the fork oil, lube the steering bearings, and bleed the brakes. FYI I just put my 2018 Brozz up for sale on OfferUp.
2019 Z 400 2020 Tan Recon 2021 KLX 300 2022 GPX FSE 450R |
03-03-2021, 09:07 PM | #17 |
What are you planning on setting your valve lash at? Are you doing it while the engine is cold or warm? I too will be adjusting my valves out of the box.
And... Do you know what Trans Gear Ratios are? lol
NO HILL TOO STEEP NO MUD TOO DEEP The Brozz | The Hawk Upgrades, Accessories, Etc... Assembly Checklist: Brozz 250 | Hawk 250 ~idle_purr |
03-03-2021, 10:04 PM | #18 | |
Trans gear ratios is the just what it states. The gear ratio for each gear. As you can see 1st to 2nd gear has the highest jump between gears ratios. This engine will lug 2nd gear quite well and 3rd too. You don’t have to work the shifter all the time.
03-03-2021, 10:08 PM | #19 |
hi Idle Purr.....valves are set cold......I do mine: intake, between .002" - .003" and the exhaust, between .003" - .005" (note that these measurements are stated in thousandth of an inch) as opposed to what you see posted by Jeff, which is metric.
The gear ratios you ask about are the 5 internal "transmission gear ratios" they are simply shown just for your information...nothing to be adjusted or maintained. Your transmission has two shafts,...an input driven by the crankshaft by way of the clutch,..and an output, which by way of the chain and sprockets,..drives the rear wheel. The ratio is the relationship of one shaft rotational speed, to the other. As far as the engine oil,...it has been mentioned on these forums, that the Brozz oil is OK for an initial break-in period....but, the general consensus is,...for the price of a quart of oil (Shell Rotella T4 15W-40 for example) and 15 minutes,....you will have good quality oil in it for sure for your break in.
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
03-04-2021, 07:16 AM | #20 |
What Cycleway4 is correct. I used the OEM oil last round to break in the engine but oil is cheap. The valves I should have read your post closer. I don’t want to send out incorrect information. I followed the bikes manual and set mine to .05mm on both the intake and exhaust. My feeler gauge has both mm and thousandth on it . Here a pic to clarify.
03-04-2021, 12:07 PM | #21 |
Mine just arrived, no birthmarks I am totally impressed, had an awesome driver too.
03-04-2021, 01:06 PM | #22 |
My two arrived around 9. I was told 11-4 . I was at work in a meeting and missed the call. When I called back the driver told me he dropped them on my driveway!! I raced home and found them by the garage door. A pain to get inside by myself . I had planned on pulling the car out of the garage and having the delivery guy roll them inside. With a tip afterwards of course. I open the boxes and peaked inside. Some paint scraped off on the top of the key bezel . I assume from them being stacked.
Kind of sux they and drop and go with no signature.
03-04-2021, 01:50 PM | #24 |
Good times! Let us know your opinion between the green and tan Recon. I was on the fence between them for a little while but very satisfied with the Desert Sand color, quite unique, and the only other vehicle i see that shares the color are the Toyota Tacoma's
03-04-2021, 02:33 PM | #25 |
Will do. I did see a jeep today with the similar tan. The Green does look nice in person too.
03-04-2021, 03:16 PM | #26 |
I agree with idle_purr on that list of goodies
My Desert Tan Recon is getting delivered tomorrow. Wife made a deal with me. Can't uncrate it until bathroom remodel is done, so I am busting my tail trying to complete that. Big tile job which can only be done so fast as I am both cut and install man (and don't do this stuff everyday). |
03-04-2021, 04:41 PM | #27 | |
03-04-2021, 05:49 PM | #28 |
My Brozz is Here!
I would like to trade garages with you!!! lol
Here is a progress report on my end. Here is a video:
03-04-2021, 06:19 PM | #29 |
I ordered a set of the Pro Taper handle bars too. But I thought they looked a lot lower than the stock ones on my 2018 Brozz. I ordered a set of risers.
03-04-2021, 06:32 PM | #30 |
Its nice to see more Brozz-a-maniacs getting on the forum these days....say your prayers, eat your vitamins and keep posting those mods!
