Old 09-05-2018, 04:51 AM   #16
Its_not_a_honda   Its_not_a_honda is offline
Originally Posted by Mycovilly View Post
Will a 400mm rear shock fit the apollo. 20mm diffrent from stock
It will. You just have to make sure the mounting holes are the right diameter and that the clevis at the bottom has enough clearance to fit the linkage on the swing-arm. It may sit a little lower.
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 09-05-2018, 09:53 AM   #17
Mycovilly   Mycovilly is offline
That might be better for me anyway. Im 5"6. The front 21" rim will be swapped out shortly with a 17" and putting some dual sport tires on.
JVilla
2009 yamaha r6
2008 yamaha r1
2018 apollo 250cc
Old 09-09-2018, 09:48 AM   #18
https://www.partsroketa.com/apollo-250cc-agb-36
