07-12-2017, 02:05 AM | #16 |
The chinese copys are a copy of the Honda 70..
Honda 90 & 110 motors are the same concept but bigger/heavyer built.. Honda wern't prepaird to stretch the 70 out to 90 then 110 they built a bigger more robust motor.. I have a CT110 and a chinese 110 copy... you can see the physical size diffrents.. the Honda 110 is a bigger motor size wise... ..
07-12-2017, 07:48 AM | #17 | |
One thing to keep in mind is that the engine stud spacing may vary slightly between Chinese engines and also may be different than the Honda spacing. That slight variation can result in mismatched parts bolted together without any dowel pins used at all to keep the top end aligned on the cases. I've seen it firsthand. |
07-12-2017, 10:42 AM | #18 | |
07-12-2017, 12:36 PM | #19 |
Since we all agree that the China pit bike engines are copied from the Honda 50-70 case, We can talk apples to apples. I'm saying that I think the 90 and the 110 China pit bike engine share a crank but have different bores. If that's true (and I'm not sure), then this kit would be a bolt-on deal: http://www.ebay.com/itm/52mm-Cylinde...lYqmHJ&vxp=mtr
The price is certainly right.
07-12-2017, 03:07 PM | #20 |
I think you are right Weld ,it seems the Chinese clones have the ability ,yet the Honda engines do not have the crank or the block machined to work with that kit .Of course ,it just opens up a can of worms ,does the head work well with the bigger cylinder,need a bigger carb with it ? ,exhaust ?
07-12-2017, 03:17 PM | #21 | |
07-12-2017, 04:06 PM | #23 |
Just an FYI, a 52mm big bore kit does bolt right up to a Honda lower end, no case boring required. You do have to case bore to go up to a 54mm big bore kit on a Honda, but shouldn't have to on a Chinese lower end, the case bore is big enough for the 54mm spigot.
I apologize if I've created any confusion... |
07-13-2017, 12:43 AM | #24 |
It's a gamble, but not much of one.
07-13-2017, 12:44 AM | #25 | |
07-13-2017, 02:10 AM | #26 | |
the head will work better with a bigger bore as the side of the valves closest to the cylinder wall have better flow because of more space.. providing you havn't gone that big that to valves are to small to fill the cylinder.... ...
07-13-2017, 12:08 PM | #27 |
I agree with your logic, Pete. Unshrouding the valves will promote better flow.
07-17-2017, 12:33 PM | #28 |
I picked it up on Saturday, the engine is the one with the semi-auto gearbox, no clutch, you just push down the gear lever to go from neutral to 4th gear, and pull up to go from 4th gear to neutral, it is a bit weird, you have to be careful when shifting to avoid a willie when upshifting or hard braking when downshifting.
Here is a video of the first ride, I figured out the reverse gear order when I saw the gear order label on the side of the bike, lol. It runs faster than I thought it would, the chinometer says 70km/h, but I have to GPS test it to get the accurate measurement. |
