Old 12-19-2016, 11:11 AM   #16
Ariel Red Hunter's Avatar
I just epoxied one of those small rare earth magnets to the head of the drain plug. It's about a 1/4" dia. but super strong. The whole drain plug is a magnet now. I can still use a socket over it.
Jerry, I think your solution to this problem is the right one.
Old 12-19-2016, 11:30 AM   #17
My wife use to do crafts and she had a butch of these magnets for refrigerator magnets laying around. They are about a 1/4" dia. x 1/4" long similar to these. https://www.amazon.com/BYKES-Neodymi...words=1%2F4%22
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 12-19-2016, 02:29 PM   #18
What a relief!
The cat lover in me clicked on this with terrible fear!
Old 12-19-2016, 02:32 PM   #19
Originally Posted by FastDoc View Post
What a relief!
I figured the title would catch everyone's attention. No worry, no animal harmed in this experiment.
2004 Honda ST 1300
Old 12-27-2016, 09:01 AM   #20
I got some ride time in over the holidays. I took my bike out Saturday and did a WOT run and cut the power then coasted to the side of the road. Pulled the plug to confirm it was running lean. So I drove back home and swapped out the 110 jet to the next size I had. a 115. I took another WOT run and pull over to check the plug. Looks like I will be close. I wish I had a 112 or 113 in my pack of jets to try. I may have one missing as I had two 100 jets. Top speed is still 74 mph (GPS) but gets there a whole lot quicker. Removing the cat is the best mod so far on this bike. I'm liking my Hawk more and more every time I ride it. I think I'll order an adjustable CDI with no rev limiter because I'm defiantly hitting the rev limit.
2004 Honda ST 1300
Old 12-27-2016, 04:56 PM   #21
Getting an adjustable CDI unit is probably a good idea. I don't agree on the rev limiter. The rev limiter is on there to protect the engine from when the rider misses a shift, or the chain breaks. It is set at 1000 rpm higher than the power peak. On the other hand, if you are hitting the rev-limiter in high gear, it's too short geared and you need to change sprockets.
Old 12-27-2016, 05:55 PM   #22
makes sense , if the operator doesn't have enough sense to hand off the throttle in that event, he probably should not be riding in the first place.
Old 12-28-2016, 09:45 AM   #23
I've been riding before rev limiter were invented lol. That's what a tach's for. I haven't ordered my digital cluster yet. (Christmas put a big dent in my Hawk budget) but will have it before I get crazy with the rpm's. not sure what the limit is set at on these Hawks but it sure ain't over reving. I have that built in tach in my ear. lol
2004 Honda ST 1300
Old 12-29-2016, 01:29 PM   #24
Digital tach/speedo
Okay, I was looking to purchase a small tachometer and ran across this https://www.amazon.com/dp/B01J7SN5MK...I24J5Q0Y2S64AK Has anyone on here installed one? The price is right. I have no problem figuring out the wiring. I could replace the whole cluster with this one for $27.
2004 Honda ST 1300
Old 12-29-2016, 02:00 PM   #25
Almost all older riders have a built in tach. People forget that tachs only came on super sports type motorcycles, in the old days. And usually you got a tach OR a speedo, not both. BSA Goldstars were the first I recall that had both. Because of Goldstars, my ear tach knows almost certainly where 7200 is by sound alone.
Old 05-29-2017, 11:05 PM   #26
Dwake402   Dwake402 is offline
How does one go about finding a cdi box for a magician/hawk?
Old 05-29-2017, 11:30 PM   #27
you be the guinea pig we will follow.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 05-30-2017, 12:39 AM   #28
I bought it and it is accurate with my gps when set correctly . The tacho, well...it gave up about a month in. Reset switch for tripometer is in back and hard to reach but is my only choice to keep up with mileage. I paid about the same. It's so cheap I could easily afford a replacement if I had to have the techno but I just really needed it to keep track of mileage.
Old 05-30-2017, 07:57 AM   #29
After reading reviews and watching a few videos I discovered one glitch with it. If you accidently change the in the settings from 1 cylinder to 2 or 4 you could not reset it back to 1. With the luck I have I would of messed it up so I went ahead and through the cheap bastards award out the window and got the digital cluster from Matt. I'm glad I did. It was plug and play with Matt's cluster.
2004 Honda ST 1300
Old 05-30-2017, 07:59 AM   #30
What was the problem with getting the tach to work ?
2004 Honda ST 1300
