Go Back   ChinaRiders Forums > Media/Reviews/Classifieds/Sponsors > Web Deals - NEW!
Old 04-04-2017, 10:41 PM   #16
Originally Posted by Wild_Alaskan View Post
not sure what software you use but if the resolution is correct, you probably need to increase the bitrate setting when exporting the video
, you got that 2lz... and check the Flux capacator
No offence wild.
Old 04-05-2017, 06:15 PM   #17
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Originally Posted by bogieboy View Post
thats easy enough to mod if really desired... crack it open, desolder the internal mic, solder a whip with a jack on the end. add a hole in the case and silicone it.... or do like most of the motovloggers and run seperate audio and video capture. then sync in the "cutting room"
I doubt it that easy as I assume the reason it doesn't have an external mic jack is because the camera doesn't record audio. Nothing in the spec's mention audio recording capabilities. It would be a lot easier and cheaper to design a camera without audio then one with audio.
