Old 04-21-2016, 10:20 PM   #16
Originally Posted by rtking View Post
I don't think this big bore kit is meant for use with the ZS177 engine, unfortunately. Our bore is 77 mm, so to get to 300cc, you'd need to go with a 84mm overbore and a custom piston.
Originally Posted by Eco Mouse View Post
Would it really matter what the new bore is vs. the old? When they are giving you a new sleeve, and piston to match? Obviously, if the bolt holes and water passages don't line up, that's an issue.
Would this make it more of a stroker? Maybe what's missing is a longer connecting rod?
RT is correct. This cylinder is not part of a big bore kit for the ZS177MM (NC250) engine. The bolt holes, lubrication journals, and water journals do not line up. This kit is designed for a 250cc ATV engine. I don't know of any big bore kit for the RX3 engine.
Here is a photograph of the ATV, big bore cylinder.
Here is a photograph of the RX3 cylinder.
The RX3 cylinder photo was taken from the following thread.
http://www.chinariders.net/showthread.php?t=15591
Old 04-21-2016, 10:28 PM   #17
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
Well, I guess that makes my decision easy... Turbo it is!
Old 04-21-2016, 11:21 PM   #18
Jay In Milpitas's Avatar
Not to mention that it would be a real pain trying to route the cam chain through the pushrod tube holes.
Old 04-21-2016, 11:52 PM   #19
Indeed. I have never worked on a pushrod motorcycle engine, but I noted the cam chain well did not extend completely through the cylinder.
Old 05-09-2016, 06:10 PM   #20
Skyteamst90   Skyteamst90 is offline
Skyteamst90's Avatar
Its too bad there isn't a 300cc enduro
Its too bad there isn't a 300cc or so enduro. Maybe there is one out there, but I am new to this, so maybe I haven't found one yet.
I think I would rather wait for the RX4 with the 450cc engine, which Zongshen plans to introduce next year.
http://www.chinariders.net/showpost....postcount=4969
On the radar: CSC - TT250
Moto Aventure ride 2020.
"If everyone is thinking the same thing, no one is thinking." Gen. Patton.
-2017 Suzuki SV650
-2015 BASHAN - STORM
Current mods: LED headlight & tail light, LED fog light, JT 428-130 chain, 47t rear sprocket, 4-fuse box, oil-cooler, CSC TT205 hand controls, 32" handlebars, aftermarket 295mm rear shock, digital speedo & tach, USB/12 volt accessory; painted flat-black.
-2005 Skyteam ST90 (sitting in pieces)
-2003 Buell Blast - SOLD
