03-12-2019, 08:42 PM | #16 | |
03-12-2019, 09:50 PM | #17 |
I don't want to mod or tinker, but a skid plate is kind of important for an off-roaded bike and I thought the XTR came with one from the factory. I also have a serious hold back for having to spend $130 for the CSC plate...that's F-ing nuts
"Talking about living life is nice and all....but a motorcycle is a tool to actually do it." -me You Tube: PaiN's Rides Currently riding the hell out of my 2013 Victory Cross Country. |
03-12-2019, 10:45 PM | #18 |
I looked for a skid plate - but nothing even for other bikes, seems local lads don't like want or think it's needed
03-12-2019, 10:47 PM | #19 |
No drain on the bottom unless some odd one has it, yeah they drain via the side cap and that cap/O ring is the same for the drain plug and the valve covers.
03-13-2019, 01:21 AM | #20 |
Maybe check this
03-13-2019, 05:49 AM | #21 |
Do you happen to have a link to that plate so I can check more into it?
"Talking about living life is nice and all....but a motorcycle is a tool to actually do it." -me You Tube: PaiN's Rides Currently riding the hell out of my 2013 Victory Cross Country. Last edited by PaiN; 03-13-2019 at 09:12 PM. |
03-13-2019, 07:37 AM | #22 |
Thanks for pointing that out. I should of known that. Same as my old 200x. I have my Hawk on the brain. lol
03-13-2019, 09:07 AM | #23 |
I have no idea if it would help you in this case, but i remember a bit back before i joined someone made a skid plate for their hawk from a Walmart cutting board. While it doesn't seem the greatest, it does seem like it would work temporarily.
03-13-2019, 07:52 PM | #24 | |
It is for vertical 125-250 engines and I suspect it is the style where the frame doesn't go under the engine. That is all and more then the listings says. Wanna try 1 out? PM me |
03-13-2019, 08:06 PM | #25 |
Off-road motorcycle 125 150-250CG vertical engine lower guard plate Modified universal aluminum alloy lower bottom plate
03-14-2019, 01:17 AM | #26 |
03-14-2019, 08:28 AM | #27 |
Those plates are too small for the XTR, plus not the protection I'm looking for.
Thanks for the heads up....I just have to decided if I want to pay the $130 for the CSC plate or not If it saves a hit to the engine just once it'll be worth it.
03-14-2019, 08:40 AM | #28 |
Just get a piece of aluminum plate and make your own. It doesn't have to be this fancy. My first one was made for a piece if 1/8" steel plate I had laying around.
03-15-2019, 05:57 AM | #29 |
OKay ...Nice work on this one I am considering fab-ing something up, problem is I don't have the facilities and tools to do it right.
03-15-2019, 07:47 AM | #30 |
The steel one was done with basic tools. I use my grinder to score the plate were in wanted to bend. I used a jig saw with a metal cutting blade to make the radius and a hole saw for drain plug access. I'm sure aluminum would be much easier to work with.
http://chinariders.net/showpost.php?...3&postcount=80
