Old 03-19-2016, 12:28 PM   #16
Lee R   Lee R is offline
Lee R's Avatar
Originally Posted by Louis Angel View Post
I did not know those RX3's weighed so much. Just does not look like there is 360 lbs of material there. My Vulcan 500 is right at 400 lbs, but looks like afat pig compared to the 270ish lb. CRF230L sitting next to it. :-D
It's a pretty sturdy motorcycle. If you remove the crash bars and luggage as mentioned the weight gets pretty close to the CRF-250L which is listed at 320 pounds. Keep in mind the RX3 has a gallon and a half more fuel which is about 9 more pounds so your at 329 basically the same. The CRF-230L was smaller but also much less power from the engine.
RX3 makes a couple more HP as well.
I don't think the weights unreasonable at all as it comes with accessories.
Old 03-20-2016, 02:17 AM   #17
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
The one thing that tripped me out was the diagonal frame up the side of the bike, wasn't aluminum, even though it totally looks like it could be. It's steel. So, I can see a light of extra weight being carried around in just the frame and all the attachment points of the secondary frame rails as well.
They could have accomplished the same stiffness if they just used regular tube there. A trellis tube frame design like Triumph or Ducati.
Old 03-20-2016, 09:33 AM   #18
jct842   jct842 is offline
Never could figure what the beak was for. I like the naked look.
Old 03-20-2016, 01:39 PM   #19
Jay In Milpitas's Avatar
The Beak.
When BMW was developing the GS, they studied effective dirt bike design details. Dirt bikes had high mounted front fenders which helped to deflect wheel spray away from the rider's face. BMW uses the beak in addition to a fender for the same reason. It's just become sort of a standard part since then,
Old 03-20-2016, 08:34 PM   #20
Louis Angel   Louis Angel is offline
Louis Angel's Avatar
Originally Posted by Lee R View Post
..............I don't think the weights unreasonable at all as it comes with accessories.
Oh I certainly agree with that. It is a good solid weight. The intention of
my statement was that I was surprised it is built as heavy as it is.
I guess somewhere in my subconscious mind I thought it would be much
lighter with all the add on stuff taken off. ( I had not previously heard of
the " 50 lbs. " thing before I first read this post )
If anything it just pushes me that much further towards buying one.
" If it ain't broke, I can probably still fix it!" ---- Tim Allen
Old 03-20-2016, 08:59 PM   #21
The RX3 is built strong, to carry heavy loads. You won't crack the subframe if you load up your RX3 for an adventure.
