12-16-2015, 10:01 AM | #16 |
Getting intimate.
One more thing, JB. On the day you do decide to do the valves for the first time, I suggest setting aside an entire day and take your time.
While you are taking off the pieces to access the valves, look around at everything else while it's exposed. Check that the harness from the rear brake switch is clear of the exhaust pipe, check hose clamps are snug, things like that. This forum is a wellspring of info. Make notes of what you've read & learned so you will remember what to check on your day of getting intimate with your Zong. To quote Woodlandsprite, that does sound a bit dirty. But in the good way. |
12-16-2015, 10:34 AM | #17 |
As usual, Jay has provided excellent advice. Budget a lot of time for the first valve adjustment of the RX3. Don't worry; the job gets easier, and goes more quickly each subsequent time you do it.
12-16-2015, 12:45 PM | #18 | |
I planned to take a whole day going over the bike. That's the main reason I haven't done the valve check. I'm having too much fun riding every day. I'll be going out of town for the holidays. So I will set aside a day before I leave, so the bike will be ready to ride when I return. jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ |
01-13-2016, 01:35 PM | #19 | |
To be certain of the original valve clearance, I contacted Gerry at CSC, and he verified that: "The valves are adjusted to .003" during set up." Notice that the measurement is in thousandths of an inch, not the .04 - .06 mm that is in the manual. The .003 " feeler gauge slid under all four valve tappets. There wasn't as much "drag" as I thought there should be, but the .004" feeler did not slide in. So I left all four as there were. I am not looking forward to adjusting the exhaust valve clearances when the time comes: One of other things I noticed was the bolts on the fuel pump cover were not tightened enough. I could unscrew them with my fingers. I didn't have the torque specs, so I used a short handled 1/4" drive socket and used 2 fingers on the handle to tighten them. The spark plug looked good: The second day I put everything back together. I had only one missing washer...not too bad. Usually I have parts left over. To be honest, this was no fun at all. It took much longer than I expected, even longer than that the valve adjustment on the Triumph Bonneville where I had to remove the whole cam assembly and change out shims. jb
01-13-2016, 01:57 PM | #20 |
Thanks for the pics. That's one clean, organized workspace!
Valve checks are definitely not easy (at least on the exhaust side), but I guess that's the price you pay with a compact motorcycle. My 2nd check went much easier.
01-13-2016, 07:59 PM | #21 |
Indeed, thank for posting the nice photos. Also, thanks for the tip regarding the fuel pump bolts; I will check mine the next time I remove the fuel tank.
Indeed, the job is a little tedious, but it will go much faster the next time. Nevertheless, I budget 3 leisurely hours for a valve adjustment.
