Old 01-25-2015, 09:41 AM   #16
Nydirtbike   Nydirtbike is offline
one more question. Have you done any other mods beside the spark plug and carb?
Do you know if theres any after market exhaust that will fit our bike to increase some power?
Old 01-25-2015, 10:20 AM   #17
Gr8rcher   Gr8rcher is offline
NY
You and I are about the only ones here right now that have this bike and I just got mine as well. It is a work in progress.
Old 01-25-2015, 11:58 AM   #18
Thanks for reminding me to check the valves. They were so tight I couldn't tell the exhaust stroke from the Compression stroke. I had to look at the valve cycling, also there is no T on the flywheel that can be seen from the sight port just a timing mark. got it done.
Thanks for the tip. NY you need to check yours.
If you're gonna go, go with a smile. (The Joker)
Old 01-25-2015, 01:48 PM   #19
The jet needle, needle jet and pilot mixture screw will be suitable for you with the 30mm Mikuni. The #20 slow jet and the #100 main jet will likely require replacement. I would just swap to at least a #25 (I'm using a #30) slow jet, and a 110 main jet before installing the carb.
Old 01-25-2015, 01:50 PM   #20
You're welcome.
I've never seen a Honda clone without the T mark!
Old 01-25-2015, 04:02 PM   #21
Frame
Carb
Valves
Old 01-25-2015, 08:37 PM   #22
awesome
Valve adjustment looks pretty hard to do.
I DONT KNOW IF I FEEL comfortable to do it
Old 01-26-2015, 08:54 AM   #23
It's not that hard. There are many tutorials that will show you better than mine.
Old 01-26-2015, 05:35 PM   #24
i guess i should try.
You get the carb in?
Old 01-26-2015, 05:59 PM   #25
Adjuster's Avatar
I am currently messing with a new carb and intake on my own project. I was just curious if anyone knows. What is the purpose of the plastic spacer that goes between the carb and intake pipe? I believe it is called an isolation gasket or something like that. Why doesn't the carb bolt to the intake pipe with a paper gasket just like the intake pipe bolts to the head with a paper gasket?
Old 01-26-2015, 07:42 PM   #26
It's an insulator, and I think it's designed to prevent vapour lock, but I'm not sure.
I tried to remove mine on my quad, but the intake no longer lined up with the carb.
Old 01-26-2015, 07:53 PM   #27
So i think ill deff need a valve adjustment.
I takes about 10 to 13 kick start cold to get my bike going. Its a new bike how does it come from the factory not adjusted ??
If i can't do it what does it usually to get them done? don't want to get ripped off
Old 01-26-2015, 08:03 PM   #28
All of the boots also have an O-ring to help prevent dirt from entering the cylinder.
Old 01-26-2015, 11:17 PM   #29
These aren't boots like Yamahas and clones. The Honda clones use a stud mount for the carb and the intake tube. There is a plastic insulator between the carb and intake tube.
Old 01-26-2015, 11:29 PM   #30
Adjuster's Avatar
Here is a crappy picture off Ebay. The plastic insulator as they call it is maybe 1/4" thick. It goes between the intake pipe and the carb and it has a rubber o ring embedded on each side to seal the connection. It must have a special purpose but I can't figure it out.
