09-21-2014, 07:44 PM | #16 |
I'm sorry, Fish. After saving my stock, Zongshen exhaust parts for years, I finally threw them away about a month ago. I agree with Weld. Buy a used, XT225/TT-R225 exhaust header on eBay. The stainless steel headers are much easier to keep clean, and rust free.
I also think you will enjoy mounting an FMF Universal Spark Arrestor to the Yamaha exhaust header. Your Zong will drop a lot of weight, and the engine will produce more power. Besides that, the FMF silencer/Yamaha exhaust header look great.
09-26-2014, 04:10 PM | #17 |
zong parts thru taobao trends
can human or spud please help,,,,,,,i tried a different coil an cdi box,,,as well as diff plugs to no avail ,,,still no spark so could you point me to the right link to the stator assmbly ?
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic. |
09-26-2014, 10:34 PM | #18 |
09-27-2014, 05:25 AM | #19 |
what is difference beteween the one you have shown,,and this one http://item.taobao.com/item.htm?id=4206462824
09-27-2014, 08:23 AM | #20 |
The one you posted is less expensive. Always search for the best deal.
09-27-2014, 12:14 PM | #21 |
Fish, you indicated that the bike was run without a battery; did you order a new reg / rec as well?
09-27-2014, 05:47 PM | #22 |
09-27-2014, 06:58 PM | #23 |
weld,,,,,yes i ordered pretty much everything electrical,,thanks to humanbeing an spud!,,,thx again to those two guys!
09-27-2014, 07:23 PM | #24 |
Good for you, Fish.
09-28-2014, 08:40 PM | #25 |
weld.....the regulator /rectifier has nothing to do with producing spark?? or does it?
09-28-2014, 08:58 PM | #26 |
No, it doesn't. The regulator/rectifier converts the AC current from the alternator to DC current, which charges the battery. It also regulates the charge going to the battery, by dissipating excess current as heat.
09-29-2014, 11:02 AM | #27 |
As Spud says, no it doesn't. The reason I asked if you ordered a new one is that you indicated the bike was run without a battery. If so, it's a good idea to change the reg / rec. They're cheap enough.
09-29-2014, 11:56 AM | #28 |
Zong parts
also In sorting. Out the no spark issue. I've found that the kills witch has been removed. I have. Two. Wires left unhooked under the headline housing. I'm assuming. These are for the kill switch. , but one of them is hot. When the switch is on. Is that possible?
09-29-2014, 03:42 PM | #29 |
What color is the wire? I will check my ZS200GY-2 wiring diagram.
The kill switch works by grounding a pin on the CDI unit. Neither of the kill switch wires should turn hot by merely turning on the ignition switch.
09-29-2014, 05:54 PM | #30 |
zong parts
spud one wire is black with a white stripe the other is faded but possibly pink or tan
