Old 08-09-2014, 02:57 AM   #16
I once bought a Suzuki that had no teeth on the front sprocket, and I only discovered that after I rode it across town. I thought the clutch was slipping.
Old 08-09-2014, 10:28 PM   #17
katoranger's Avatar
Report back. I am expecting positive results.
Old 08-10-2014, 12:45 PM   #18
rfincher86   rfincher86 is offline
Got the sprocket installed. It does a lot better, still not as much torque as I would like but it doesn't feel like the clutch is slipping anymore. I have some clacking coming from the engine, I think I need to adjust the valves.
Old 08-12-2014, 12:48 AM   #19
tires
you can check to see if the tires are any larger than what came from the factory... go to WWW.CANADTTATV.COM and you can check for the 125 F1.. the change in gears help... you may have a little less power due to wear & tear... but I sell these and I weigh 200 lbs and they haul me around pretty good... as far as climbing.. I do not do that part... you can also check to make sure you are getting full throttle ... clean the carb... change the jets... this will increase you power... WELD is a good one for jet sizes... good lucK AND ENJOY THE RIDE
ABIBABA ATV ETC
