Old 07-04-2014, 02:16 PM   #16
hect75   hect75 is offline
hect75's Avatar
Led turn signals are working but the ignition switch is not. I have to kick start la moto because the ignition switch only clicks. I will check this weekend the wires in case something loose. Any ideas? I noticed this problem after modifying for led lights.
Hector
Mountrack Vento 2006
Old 07-05-2014, 12:07 AM   #17
Krasi_BG   Krasi_BG is offline
Is the battery fully charged?
Also, check for current "leaks" when everything is off.
Old 07-07-2014, 11:16 AM   #18
hect75's Avatar
Yep, it's fully charged. I will shift the relay and see if it works with the old flasher relay although, in my opinion, this one should not affect the ignition. Will post results the coming days.
Hector
Old 07-08-2014, 04:59 PM   #19
hect75's Avatar
I found the problem. It was a loose wire in the battery clamp (the thin one connected directly to the fuse). Once it was tightened, ignition relay worked.
Hector
Old 07-09-2014, 11:00 AM   #20
Good news! Glad to hear you solved it.
Old 07-09-2014, 02:07 PM   #21
X2.
