Thread Tools Display Modes
Old 07-03-2014, 07:44 PM   #16
humanbeing's Avatar
These?
http://www.aliexpress.com/item/BRAND...373989837.html
Old 07-04-2014, 01:39 AM   #17
Humanbeing, you're awesome. If you're ever in BC, I'd like to buy you a beer.
Old 07-04-2014, 01:55 AM   #18
X2.
Old 07-27-2014, 12:33 PM   #19
Hey Humanbeing, can you please tell us what these symbols mean? E1, PC, E, IGN (my guess is ignition power), EXT and SW
Old 07-27-2014, 04:48 PM   #20
humanbeing's Avatar
E / E1 =Earth (Ground)
PC= Pickup (Trigger…)
SW= Switch
ExT= AC in
IGN
http://www.dansmc.com/electricaltesting.htm
Old 07-28-2014, 02:03 AM   #21
Thank you very much. After a little searching online, I found the answer, and was able to sort out my wiring. I'll post about it soon.
Old 08-10-2014, 01:50 AM   #22
HB, how would I search for this CDI harness? I specifically want the rounded four pin that has two green wires, not one.
Old 08-10-2014, 03:57 AM   #23
humanbeing's Avatar
Chinese calls that 4 pin as DJ7041-2.3-20 officially
Example of that 7041 family http://item.taobao.com/item.htm?id=14816193977 DJ7041Y-2.3-21 (Left)
2.3 stands for 2.3mm | Terminal example: http://item.taobao.com/item.htm?id=16419446610
DC-090: http://www.cycleterminal.com/motorcycle-connectors.html
Use these http://item.taobao.com/item.htm?id=25759660491 OR crimp some "2.3" to build whatever u want.
In my rusty memory, i don't remember ANY Honda based chinese CDI uses both ground.
Key OFF in DC CDi = cuts +12V ONLY http://www.mobile01.com/topicdetail.php?f=266&t=2234502 or BOTH +12v & PC
Key OFF in AC CDi = as #20
Old 08-10-2014, 12:11 PM   #24
Thanks for the links. My Roketa has two green wires, as pictured above. If I use one of the two spare CDI's I have, I cannot shut off the engine. The pinout is different, and they need a connection to the other terminal. I'll convert all of my China machines to use both ground terminals, so I can swap CDI's as necessary.
Old 08-17-2014, 07:49 PM   #25
I need to order a new master cylinder (with mirror mount), hose (preferably braided) and caliper. Can you help me find what I need? Below is what I have:
Old 08-17-2014, 07:52 PM   #26
Also, can you help me find a new speedometer (in km/h) and shift indicator / signal indicator / high beam indicator? I wrecked mine when I splashed it with brake cleaner.
Old 08-17-2014, 08:31 PM   #27
I need to order a new master cylinder (with mirror mount), hose (preferably braided) and caliper. Can you help me find what I need? ...
The front brake for my Zongshen 200GY-2 looks very similar to yours, Weld. I just ordered a spare from Taobao.com, so I know you can get one.
Old 08-17-2014, 10:37 PM   #28
May I please have the link, Spud?
Old 08-18-2014, 01:21 AM   #29
Of course. Here is a link to the complete front brake assembly.
http://item.taobao.com/item.htm?spm=...02&ns=1#detail
I recently bought a spare master cylinder for the front brake.
http://item.taobao.com/item.htm?spm=...55&ns=1#detail
Those are the first items I found; you might be able to find a better prices.
Old 08-18-2014, 09:10 AM   #30
humanbeing's Avatar
上(up)泵(pump)
http://item.taobao.com/item.htm?id=13864452796
下(down) 泵
http://item.taobao.com/item.htm?id=7782195289
编织 (braided) 油(oil) 管 (hose)
http://item.taobao.com/item.htm?id=39034462085
仪表 (instrument)
http://x2moto.taobao.com/search.htm?...Type=price_asc
