03-24-2014, 01:09 PM | #16 |
You can also spray some brake cleaner or carb cleaner onto a cloth and rub it on the QLink letters. It sort of removes the shine from the vinyl, but it's not bad.
Your bike looks awesome! I have a tail that I think is for a Q, and it has an LED tail light. Interested?
04-05-2014, 04:03 PM | #17 |
Okay so I've done a few things since my last post
First of all I put togethar my fender eliminator. It took me a good days work to get it where I like it and mount the LED tail light I got off ebay for $11. I just made it out of a chunk of sheet metal. Also thanks for giving me ideas on removing the Qlink on the seat, turned out great. Next, and this is the exciting part, I got my FMF turbine core II After a few minutes cutting and sizing it turned out perfect, its loud as hell D Now it ran perfect and it's awesome and everything with the exhuast and the Jets HOWEVER. This morning I moved the needle clip to the 4th position down and my problem arised. It starts and idles great, but when I first rev it in any gear it chokes, once I get past the choke point it flys like hell with a noticeable power gain. How can I fix this? Does it need more air/running too rich? or should I just move the needle clip back into the 3rd position from the top where it was??? I'm thinking a K&N airfilter to replace the airbox? Here's picks of it looks like: [IMG]http://i162.photobucket.com/albums/t257/ostap34/0405141241_zpse79a1fe7.jpg[/I MG] |
04-05-2014, 07:20 PM | #18 |
Great bike. I miss my Q's. sounds lean.
Happy to serve. |
04-05-2014, 10:05 PM | #19 |
Did you do all of your mods at the same time? It's better to do them one at a time and check performance. I used to have the same bike as yours. There was a noticeable gain in performance with the new pipe and stock jetting. Try putting the clip back and check your performance. Eliminating the air box is not easy on these bikes because of the type of carb. It is a CV and is supported on each side by the box and the head. Removing the box will require you to support the carb with some sort of bracket. Sprocket changes were mentioned. It comes with a 15/48. I changed to a 16/44 and was happy with it. Again, one step at a time. Change the front to a 15 (cheapest and easiest) and see how you like it. I like the eliminator you did. I did something similar but with the stock tail light as it was an LED already.
04-05-2014, 10:32 PM | #20 |
That is a stunning bike!
04-05-2014, 10:35 PM | #21 | |
Will changing the front to a 15 give me more power or top end? And where can I order one? |
04-05-2014, 10:36 PM | #22 |
I love my FMF Universal Spark Arrestor; it looks great on your XF200. After a few thousand miles you will need to repack the silencer, since it will quickly blow out the 2-stroke packing. Here's a link to my thread detailing how to repack your silencer with 4-stroke packing, which will last much longer.
http://www.chinariders.net/showthread.php?t=7514
04-05-2014, 10:36 PM | #23 |
thanks haha. It's my first *street legal* bike after playing with little 50cc dirt bike and pocket bikes for 4 years.
04-05-2014, 10:38 PM | #24 | |
04-10-2014, 11:29 PM | #25 | |
04-21-2014, 05:13 PM | #26 | |
The OP's bike looks amazing. Love the black.
