Old 06-27-2013, 02:13 PM   #16
gagab1   gagab1 is offline
Simple... bogieboy i like the way work on this kind of bike. So i will post detail photo/video of valve saturday.Thank you... all of you are very helpful
Old 06-27-2013, 03:17 PM   #17
bogieboy's Avatar
i figure the level of precision used in working on them is only needed to be equal to the precision used in manufacturing them.....LOL
Old 07-02-2013, 08:50 AM   #18
Hey guys! pics of the engine will be uploaded tonight sorry this weekend my GF was moving so i dont have time to check on the bike.
Hope you have a great 3 days weekend!
Old 07-02-2013, 10:33 AM   #19
So, i do a lot of research the engine is a CB250
This one!
Old 07-02-2013, 12:23 PM   #20
It's probably 223 or 230, but a very good engine. Regular oil changes are very important, since there are no cam bearings, just like a Honda.
Old 07-02-2013, 02:13 PM   #21
To night i will mesure the piston size... hope the 67mm piston i order will fit.
Old 07-02-2013, 09:13 PM   #22
This engine will need a lot of cleaning.
this is SN
Old 07-03-2013, 10:19 AM   #23
That serial number indicates a 69mm bore, but it could be wrong. Measuring is the best way.
Old 07-03-2013, 10:28 AM   #24
So is the piston size needs to be the same bore size?
Old 07-03-2013, 01:44 PM   #25
Pic of the old piston this is horrible.
I can confirm its a 65mm piston...
Did you thnk the 67mm will fit ?? or the sleeve must be bored?
Old 07-03-2013, 06:01 PM   #26
humanbeing's Avatar
http://item.taobao.com/item.htm?id=14554046635 is what u need if don't want to pay someone for the re-bore (67mm) done.
Old 07-03-2013, 09:54 PM   #27
Ugh. That piston looks nasty!
To respond to your question, the cylinder and piston will be very close to each other (if everything is correct). For example, an XR200 will have a 63.42mm piston and 63.60mm cylinder, if everything is well worn. A new engine is much tighter. If you intend to bore out an engine and use a new piston, usually 0.5mm is removed.
Old 07-03-2013, 10:34 PM   #28
So waht is the best way? Bored the cylinder to 67mm or buy a new 65mm piston and ring?
This is the piston i ordered.
http://www.motopartscenter.com/pisto...rt-p-1427.html
Old 07-04-2013, 01:36 AM   #29
The piston looks awful, but how does the cylinder look? Does it have scratches that you can feel with a fingernail? What is the measurement at the top, middle and bottom? If it is not more than .25mm bigger than the piston, it will work.
If the measurements are ok, you can hone the cylinder with a brake cylinder hone from the auto parts store and install the piston you bought. If the cylinder is no good, just buy a new one that matches the 67mm piston. It will probably be cheaper than paying somebody to bore the existing cylinder.
Old 07-04-2013, 07:26 AM   #30
Yep... The sleeve as a little chunck of piston at the very bottom point. But it think a can remove it.
And if i buy a new cylinder the one that humanbeing show me will be correct?
Like this one cg250?
http://m.motopartscenter.com/index.p...ke+%26+Go+Kart
