06-25-2013, 07:47 AM | #16 |
well, mate, did you get onto this forum expecting to be told to use a mechanic?
the best in that department, since you don t know one, would be to find someone who works on pitbikes and ATVs. they understand the chinese scene. OR spend all that money on tools and develop the know-how. that s why many here have several bikes, some to use, others to fix. that reduces the frustration factor and, well, it is fun. but i agree, if you don t have time right now that wont work for you.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
06-25-2013, 07:23 PM | #17 |
Yeah it could be fun Zingshoen
Great to have been told about this forum Going to do a few checks on the bike myself today |
06-25-2013, 10:19 PM | #18 |
Welcome to here, Overlander. The problem with having your bike is that Skyteam has not brought it to N. America yet (although on ST's facebook page, the moderator or host of their official page stated they are getting its certified-yes!). Instead, you will have to rely on a Bulgarian and German who own the same bike in their respective countries, and have already introduced themselves.
06-25-2013, 10:22 PM | #19 | |
06-27-2013, 05:27 PM | #20 | |
THe original spark plug has the number D8RTC. Chances are you won't find a spark plug with this number anywhere - I didn't. So I took the time and went through many lists to get the equivalent Plug from other brands. I have the NGK DPR8EA-9 one. The spark plug gap should be 0.6mm-0.7mm (0.02-0.03in). Normally it's ok with new spark plugs. NGK DPR8EA-9 Nippon DENSO X24EPR-U9 NGK iridium IXDPR8EIX-9 Champion RA6HC Bosch XR5DC
My CB : http://www.youtube.com/watch?v=ZbZ8q-grmOQ 2012 Skyteam V-Raptor 250 2011 Yamaha Tenere XT 660Z abs 1996 Kawasaki Vulcan 800 Classic 1989 Kawasaki GPZ 500 |
06-27-2013, 10:49 PM | #21 |
Thank's guys... I changed the spark plug and guess what. The Black Wombat is now starting and running!
06-28-2013, 12:45 AM | #22 |
Most spark plugs aren't very expensive. It's good to change them on a regular basis.
06-28-2013, 04:43 AM | #23 |
Some manufacturers recommend changing the plug after the initial break-in. I threw the original one away after the first heat cycle
06-28-2013, 11:02 AM | #24 |
That's good news! I haven't had good luck with China plugs in stuff I've bought new, but two of the (very) used China bikes I have both still had the stock plug! I guess you get a winner occasionally.
06-29-2013, 07:12 AM | #25 |
Just wondering if anyone has had to adjust their throttle. Mine has been sticking and is quite lose when you turn it. I tried adjusting the adjuster nut, but it appears to be lose where the cable enters the part on the handlebars (see photo) Has anyone had to pull this part apart. Any suggestions?
Also does this weld on the bottom of the rear shock look ok? It doesn't appear to solid (see photo) |
06-29-2013, 04:13 PM | #26 |
I'll defer to someone who has that type of bike to chime in on the throttle.
That weld looks like it has good penetration. If you were to try and weld it fully, you'd risk destroying the bushing. I'd leave it.
06-29-2013, 06:53 PM | #27 |
great looking bike!
the throttle cable will need to come off to be greased and perhaps rerouted. it is likely to be sticky because it is too tight somewhere under the tank. reroute it and use a couple of zip ties, make sure there s no kinks and squeezes. it will come unstuck and perform. use some additional nuts on top of carbie if possible as spacers to reduce cable slack. bit of cable slack is fine. if you want less throttle turn, you ll need another setup, more like an dirt bike. take a look at my nifty zongifications thread in the DS/Enduro section, it shows you a halfturn throttle
06-29-2013, 09:57 PM | #28 |
Interesting; there's a place for another throttle cable yet you don't have one. Please post more pictures of your carb and motor from both sides. That will give us a better clue as to what your bike is based on. That will help part replacement if you need them. So far, the general layout looks to be based on a Yamaha TW200 what with the big back tire. Your motor looks Suzuki-ish with the oil filter on the right side, however. The ones on the website are definetly Honda based. By the way, if Suzuki based, the motor should be 249cc and if Honda based, probably 223cc like Trailbikeryder siggests.
06-30-2013, 05:57 AM | #29 |
Indeed most probably it's routing of the throttle cable. Last time I had to mount the tank, I had to take it off, and then on twice to unstuck it. It's best not to tuck it in, under the tank and between the frame, but rather let it hang "freely".
07-02-2013, 01:22 AM | #30 |
Just in Melbourne at the moment, will post more photos when I return to the country. The metal part that goes into the connector on the handlebars appears lose. Might have to pull it apart to see if I can tighten it. Thanks for all comments
Tags |
australia, skyteam, v-raptor 250, v-retro 250 |
